What's the over all consensus with K&N Engine Air Filter's for our Taco's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pearson, Oct 1, 2022.
  1. Oct 1, 2022 at 4:46 PM
    Pearson
    Pearson [OP] Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    I used them in the past. Not as much for performance but more for hearing that they are good for your engine. And I like the thought of cleaning in place of buying. You hear equal good and bad info so your left kinds where you started.
    But I did personally have a bad experience with one in my Focus as within a few days check engine light cam on and I lost like 3MPG. So what about the 2nd gen 2.7L? Went back to normal as soon as I went back OEM.
    What do you know about it?
  2. Oct 1, 2022 at 4:47 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The word you want is "consensus".
    Also K&N filters do not filter as well as factory paper/fiber. They are basically junk for engine health.
  3. Oct 1, 2022 at 5:09 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I use a regular paper filter.
    inwood customs and Speedbird like this.
  4. Oct 1, 2022 at 5:38 PM
    Soulsurvives
    Soulsurvives Well-Known Member
    Bill
    2009 Tacoma
    They add engine sound for sure. I had one on my 2009 4.0 and took it off because the wife did not like it.
    Pearson[OP] and inwood customs like this.
  5. Oct 1, 2022 at 5:43 PM
    Bishop84
    Bishop84 Well-Known Member
    They add noise and make a life time air filter for the truck. That’s about it.
    I don’t discourage buying it, but I stress that they need to be serviced with limited oil.
  6. Oct 1, 2022 at 6:29 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For most people there is no measurable gain in performance or fuel mileage.
    Long term you may save a little money by not having to buy replacement paper filters.
    They don't filter the air as well as conventional filters. If you drive in dusty conditions, I'd certainly avoid them.
    I used one on a truck I used to own. After selling that truck I never went back.
  7. Oct 2, 2022 at 2:17 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    If you want a filter you can clean and re use prob Better off with an AFE, they don’t need to be oiled. Doubt there’s any performance gains though
    TacoCat and lynyrd3 like this.
  8. Oct 2, 2022 at 2:30 AM
    lynyrd3
    Bill
    East Central Upstate NY
    X2 :thumbsup:
  9. Oct 2, 2022 at 4:03 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Be cautious to that the filter media remains intact. Recently while inspecting and prepping to clean a K&N used in our Ford van, I noticed areas where the cotton gauze filter media had holes. Those areas were not filtering at all.
    Contacted K&N expecting a warranty replacement. They stated what I found does happen on older filters and would not warranty the filter as it was slightly beyond the 10 year warranty.
    The van being only street driven survives fine, but an off road vehicle could destroy an engine.
  10. Oct 2, 2022 at 5:19 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    K&N air filters are either loved or hated on multiple enthusiasts car and truck sites that I follow. They sell millions of them. I have yet to find a definitive link between K&N filtering efficiency and catastrophic engine failure, or even shortened engine life. An extensive online search, I have yet to find a documented engine failure that is the result of inefficient K&N filtering media. Even Toyota offers a TRD Pro filter, similar to K&N. "Almost" every negative review of K&N point to various studies (which I do NOT dispute) documenting the K&N filter media as not being as efficient as paper media. What the studies don't show, is the relationship between air filtering efficiency and engine life. And I suggest that, it is because the effect is negligible in normal driving situations. (the engine sucks in the parts per million variance (particles) and spits them out the exhaust pipe with little to no effect on cylinder wear). Even in ultra dirty situations, the filter just needs to be cleaned more frequently. I have used K&N filter for years on and off road. Saved a ton of dough over the years. Not likely to change any minds here, but, K&N air filters do have a place as an aftermarket replacement for many applications.
    TRDSport10, PMK, Pearson[OP] and 3 others like this.
  11. Oct 2, 2022 at 5:41 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Modern engines are not restricted like they were in the 70s (before computer modeling)
    I've had them on old vehicles, took them off when I discovered oily dirt in the after the filter. I stick with paper now.
  12. Oct 2, 2022 at 6:38 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    The ONLY place I'd consider a K&N in my truck is the cabin air filter.
    In the engine, no way. I'll stick with paper.
    ridefreak likes this.
  13. Oct 2, 2022 at 7:10 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm skeptical of the ability to clean them. Getting it wet with water isn't going to make months/years worth of dirt and dust just magically get up and walk away from the filter media. Seems gimmicky.
    Every time I see one in a customer's car it's dirty, soggy and gross.
    A new paper filter is 20$ at most. That's my coffee budget on weekday.. just buy a new one
    TRDSport10 likes this.
  14. Oct 2, 2022 at 9:47 AM
    jbrnigan
    Midwest
    For those who can't figure out to clean, dry and re-oil a K&N filter - you need to stay with paper.
    Pearson[OP] and racerX969 like this.
  15. Oct 2, 2022 at 10:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How do you know its "cleaner" after washing? How do you measure something like that?
  16. Oct 2, 2022 at 10:16 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    My trusted mechanics say No... So, I do the OEM paper. Pretty easy and inexpensive.
  17. Oct 2, 2022 at 10:30 AM
    surforegon
    surforegon 2015 TRD
    Portland, Oregon
    I tried a K&N oiled filter for a little bit. One day my check engine light came on so I took my truck in to the dealership to see what was going on. Apparently… over time just from airflow through the K&N oiled filter, a light sheen of K&N oil coated the bulb and wires of the mass airflow sensor, so the engine computer couldn’t get an accurate reading on intake airflow. The tech cleaned it with MAF spray and showed me what was going on. It was an easy fix, but I switched back to stock Toyota filters since then.
    TRDSport10 and GrizzledBastard like this.
  18. Oct 2, 2022 at 1:33 PM
    winkel
    Corydon, IN
    I'm sure most of us could figure it out. Maybe I'm just lazy. I like to toss the old one, put in a new one and go on with my life.
    I used to rinse out my Fram oil filters and reuse them too but after blowing up a couple of engines, decided to just replace them.
  19. Oct 2, 2022 at 2:09 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I think it’s largely opinion based and many of the opinions are based on absolutely nothing. That any most if not all the problems with them come from user error. People put them in and go way to long before cleaning and maintenance and when they do they significantly over oil causing problems with the maf sensor. I have 2 for my Tacoma so I can switch it out and have plenty of time to clean and dry then I can oil a few days before changing it out. I’ve done this for years with 0 problems. I run stock in my other vehicles also with no problems. I’ve found if used correctly it’s the equivalent of installing a performance exhaust tip. You don’t loose or gain anything. Small change in engine sound but fairly insignificant imo.
    CharlesB likes this.
  20. Oct 2, 2022 at 2:15 PM
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    2015WhiteOR likes this.
