What's the part number on your Nav SD card and map date?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scooby24, Dec 31, 2016.
  1. Jan 14, 2017 at 8:38 PM
    #141
    securekey
    securekey Well-Known Member
    2018 TRD Off-Road DCSB - Blazing Blue
    This would imply the software is somehow connected to the actual SD card which makes sense. People are buying them from ebay and updating with no dealer computer equipment etc. The only reasons for it not to work on a cloned card is something that is being read from the hardware of the SD card.
  2. Jan 14, 2017 at 8:47 PM
    #142
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Post #77
    Taco16LB likes this.
  3. Jan 15, 2017 at 6:26 AM
    #143
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    You can usually buy the card directly from the dealers parts department without paying for the install but at ~$160 for just the sd card it's still a ripoff.
  4. Jan 15, 2017 at 12:44 PM
    #144
    jmdwifi
    jmdwifi My Inferno
    Fredericksburg, Virginia
    See profile
    So they do not need to do the tech stream thing to make it work? I actually wouldn't mind buying it if can plug it in, have it work, then walk back in and get the lying butthole and the manager to show them what a lying ripoff he was trying to be.
  5. Jan 15, 2017 at 12:52 PM
    #145
    gpb
    Atlanta
    @jmdwifi Maybe post up in your region and see if there's someone with the new car willing to meet up and try a swap?
  6. Jan 15, 2017 at 1:04 PM
    #146
    zinger
    If you google 86271-0E184 you'll see quite a few Toyota dealers pop up where there sell it online thru their parts department. Haven't tried it yet but I have read reviews of people who purchased the previous sd card (0E183) and they said all they had to do was pop it in and wait about 10 minutes for it to load and everything was fine.
  7. Jan 15, 2017 at 2:19 PM
    #147
    jmdwifi
    jmdwifi My Inferno
    See profile
    Cool
    Thank you
  8. Jan 15, 2017 at 2:52 PM
    #148
    CWR
    CWR Member
    Southwest Virginia
    2017 Tacoma TRD OR SB Inferno
    17" TRD Pro Wheels with Goodrich KO2's Premium Tech. with JBL
    Just checked my truck......86271 OE184
  9. Jan 16, 2017 at 1:29 PM
    #149
    ppauly
    ppauly Member
    Paul
    Success!! Had 183 downloaded 184 from your google drive. Took my card with 183 on it and formatted it to fat32. Then copied the img file of 184 I downloaded and inserted it in my radio. Did some updating then it asked to turn off car and turn back on. Did some more updates then vola its updated!
  10. Jan 16, 2017 at 1:33 PM
    #150
    DodgeORama
    DodgeORama Well-Known Member
    Dodge
    Squamish, BC
    2017 MGM TRD Off Road DCSB
    yaaarrr
  11. Jan 16, 2017 at 1:44 PM
    #151
    securekey
    did you try the gps? does it work and load the maps? Also, did it confirm the update if you look in the settings?
    Spare Parts likes this.
  12. Jan 16, 2017 at 1:45 PM
    #152
    ppauly
    ppauly Member
    Paul
    Yes and yes
    Spare Parts, over60, gpb and 3 others like this.
  13. Jan 16, 2017 at 2:04 PM
    #153
    Hank Heel
    Hank Heel Well-Known Member
    WA
    That's excellent news:thumbsup:
  14. Jan 16, 2017 at 2:09 PM
    #154
    securekey
    People are going to want details.
    What program did you use to format to fat32?
    What program did you use to copy the downloaded image to the SD card?
    Thanks and glad it is working. So far we have 1 that worked and one that didn't with apparently the same steps.
  15. Jan 16, 2017 at 2:16 PM
    #155
    ppauly
    ppauly Member
    Paul
    I used mini tool partition to format to fat32 because I had it open at the time. I'm sure you can just use windows. Then I simply use win32diskimager to copy over the image file.
    securekey likes this.
  16. Jan 16, 2017 at 2:18 PM
    #156
    ppauly
    ppauly Member
    Paul
    The key might be that I used the original 183 sd card. Maybe something with that made it work?
  17. Jan 16, 2017 at 2:27 PM
    #157
    gpb
    Atlanta
    Very curious. We definitely need more samples... Mine's a 184 so that doesn't help. I did attempt to duplicate it twice (once on Win, once on Mac) to a different card and it failed, though whether it was due to the card not being Toyota or due to the card being a 32GB microSD instead of 16, I don't know. The latter shouldn't matter but who knows at this point.
  18. Jan 16, 2017 at 2:38 PM
    #158
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    Downloading now. Going to work out. Should be done by the time I get back. Will try it this evening and report back.
  19. Jan 16, 2017 at 3:23 PM
    #159
    Edmontontaco
    Edmontontaco Well-Known Member
    Alberta, Canada
    2016 Black TRD Sport
    Im about half downloaded, I also got carbon copy cloner. Can someone explain how to make a back up of the 183map and also how to copy the 184 file onto to card?
  20. Jan 16, 2017 at 3:38 PM
    #160
    loltacos
    loltacos New Member
    Tundra... Whoops.
    I have the 0E182 sd card. I used dd (command line tool) to flash the 0E184 image to my 0E182 microsd card. It applied an audio system update, but then stated it could not read map data. Tried restarting and reinserting the microsd card, no difference. Flashed my backup image (also made with dd) and was back up and running with my old map data.
