Whats the right Drill Bit?
Discussion in 'Garage / Workshop' started by Supra TT, Feb 4, 2015.
  1. Feb 4, 2015 at 4:55 PM
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I am looking for the right drill bit for drilling out 9/16" holes that have been laser cut out. I need to enlarge them to 5/8". There is so many different drill bits I don't feel like wasting my money on buying numerous ones since I don't know what is best. I'll probably need to drill about 20 holes with it.
    I read somewhere carbide tipped drill bits might be best... ?
  2. Feb 4, 2015 at 5:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    In steel I presume ? What about a step bit .
  3. Feb 4, 2015 at 5:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    x2
  4. Feb 4, 2015 at 6:29 PM
    Supra TT
    Eric
    Indiana
    Yea it's steel. Brackets are too thick for a step bit.
  5. Feb 4, 2015 at 6:33 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Absent a step bit - I never get a neat hole when overdrilling a hole like that.
    The bit always wobbles eccentrically creating a chewed out looking hole rather than a neat one.
    Could you use a step bit half way from both sides?
    Drilling a deep hole in steel - use a cobalt bit.
  6. Feb 4, 2015 at 6:33 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Can't drill from both sides? Thicker than 1/4"?
  7. Feb 4, 2015 at 7:01 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you fasten the steel onto a wood backing board, and put a small pilot hole in the wood in the exact center of the existing 9/16 hole, this bit might work well for you:
    http://www.mcmaster.com/#8914a55/=vrqtby
  8. Feb 4, 2015 at 7:03 PM
    OZ-T
    Peter North
    British Columbia
    5/16" ?
  9. Feb 4, 2015 at 7:06 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Conversely, if you just clamp the piece tightly in a drill press, with the existing hole centered on the drill bit, you might get a neat hole with just a drill press and some cutting oil.
    What I said above about overdrilling was when I was handholding the drill...
    In that case -
    http://www.mcmaster.com/#8939a12/=vrqw65
  10. Feb 4, 2015 at 7:08 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    that's the "screw size" it's designed for countersinking a hole, and you'll notice the large diameter is .625 which = 5/8"
  11. Feb 4, 2015 at 7:08 PM
    OZ-T
    Peter North
    British Columbia
    Clamp the pieces in a drill press like Steve said , centre the hole by chucking a 9/16" bit in the drill and use that to make sure you are aligned with the existing hole , change the bit to 5/8 and drill
  12. Feb 4, 2015 at 7:10 PM
    OZ-T
    Peter North
    British Columbia
    Oh , I see that now , interesting bit
  13. Feb 4, 2015 at 7:12 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    McMaster Carr has every interesting tool in the world :cool:
  14. Feb 4, 2015 at 7:13 PM
    OZ-T
    Peter North
    British Columbia
    Not all of them , for that I go to Lee Valley
  15. Feb 4, 2015 at 7:18 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I would NOT have thought of that - and would have spent *way* too much time centering on the tapered cutting edges of the bit. :eek:
  16. Feb 4, 2015 at 7:23 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Ahhhh wood working tools. I can smell the sawdust alread. :cool:
  17. Feb 5, 2015 at 4:00 AM
    Supra TT
    Eric
    Indiana
    That's a good idea, I'll keep that in mind when drilling! :cool:
    Also, the brackets are basically shock and link brackets and you can't drill from both sides since it's so close to the other hole. They are 1/4" thick, some thicker. I just know when they laser cut the holes out on the brackets it hardens the steel around the hole and wears out drill bits pretty quickly.
  18. Feb 5, 2015 at 5:23 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It really depends on the laser used to cut it. The HAZ is going to be .001 to .004 on most lasers on the market today. you should be fine with Cobalt bits i use Viking industrial bits made by Norseman drill as long as your drilling the hole .010 larger or more you shouldn't have a problem keeping the cutting edge of the bit of the HAZ. Just drill at the right speed and use lots of cutting oil.
  19. Feb 5, 2015 at 7:52 AM
    Supra TT
    Eric
    Indiana
    OK cool. Thanks! :)
