whats the weight difference between steel and alloy
Discussion in 'Wheels & Tires' started by t.hornstra, Jan 27, 2009.
  1. Jan 27, 2009 at 9:56 AM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Little this. Little that
    im looking at new wheels.
    procomp 1069 16x8s to be exact
    ive seen some steel wheels that are similar looking but cheaper.
    can my 2.7L with a 3inch lift tell the difference between 16x8 steels and 16x8 alloys?
  2. Jan 27, 2009 at 10:40 AM
    sonjay
    sonjay Well-Known Member
    Most definitely alloys will be a bunch lighter. 10+lbs per wheel easy. Thats all weight your truck has to turn (rotational weight) the heavier the wheels and tires, the more energy required to turn them. There's nothing wrong with steel wheels though.
  3. Jan 27, 2009 at 1:07 PM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    so for my 2002 2.7 i should probably look at Alloys? I just want to make sure i don't stress the engine too much. i also make trips to Tahoe so I don't really want to sacrifice any power for the climbs and hills.
  4. Jan 27, 2009 at 4:57 PM
    sonjay
    Your truck came from the factory with steel wheels? Your not going to hurt anything with steel wheels, but you might notice a slight improvement in fuel economy and power with alloys? Weather or not its worth the money is up to you. Most people get alloys because in their opinion they look better. Performance isn't the most important thing usually. That being said you won't find a race car of anykind that has steel wheels.
