Whats this noise??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1990wade, Sep 25, 2011.
  1. Sep 25, 2011 at 9:12 PM
    1990wade
    1990wade [OP] BASS FISHING
    Wade
    Danville, Georgia
    05 TACO TRD OR PRERUNNER
    Ok so lately i have noticed a sqeaking noise from the rear when i accelerate on the gas and when i let off it quits...Starting to get very annoying i must say lol...Any info would be great..
  2. Sep 25, 2011 at 9:16 PM
    inesshell
    inesshell blah blah blah
    john
    Superwhite 10' AC
    could be the carrier bearing going bad?? the squeak i have in the rear is usually my leafs... but its only there when i go over uneven pavement
  3. Sep 25, 2011 at 9:21 PM
    1990wade
    Wade
    Danville, Georgia
    Yea i get that squeaking from my leafs to, but this just happens when i accelerate on the gas
  4. Sep 25, 2011 at 9:25 PM
    inesshell
    john
    Superwhite 10' AC
    check the bolts on your drive shaft and the bearings if they are worn. check for any loose bolts near that area as well.
  5. Sep 25, 2011 at 9:27 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    U joint, try shaking the axle up down left and right at each u joint to see if there is any play. There should be none. If there is, then replace. You can also shoot some grease into them to see if squeaking goes away.
  6. Sep 25, 2011 at 9:30 PM
    inesshell
    john
    Superwhite 10' AC
    also check the exaust?? The cats maybe. Just throwing all the areas of trouble. U bolts are good too ^^^
  7. Sep 25, 2011 at 9:35 PM
    1990wade
    Wade
    Danville, Georgia
    Thanks for the info guys i will get to this in the morning
  8. Sep 25, 2011 at 9:36 PM
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    probably just the leafs, same issue here when you hit the gas it rocks weight flexes leafs and squeaks
  9. Sep 25, 2011 at 9:38 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    99% sure it's the u joints on your shaft. Happened in one of my old trucks
  10. Sep 25, 2011 at 9:59 PM
    1990wade
    Wade
    Danville, Georgia
    So how do i go about fixing this if it was the U joints??? sorry im not good at workin on vehicles lol
  11. Sep 25, 2011 at 10:10 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    U joints are fairly easy. Pair of needle nose pliers and some wrenches oughta do the trick. Just be sure to assemble the shaft the same way as you dis assemble it, meaning match mark it.
    The u joints have clips in the outer part of the yoke to hold them in. Use needle nose pliers to squeeze them and pull em the clips out. Next press the u joint out side to side. If you can't do this by hand then you will have to get a large C clamp and two sockets, ome small to push the u joint and one large so that the u joit can slip inside of it. If you don't feel comfortable doing this, take it to a transmission shop to have them replace it. I had a Tundra with a bad u joint that I couldn't get the u joint out of and the shop I took it to had to send it out cuz their press couldn't do the job. Then I had an old Lincoln Towncar that I did u joints and just pressed them by hand. So take your time and pay attention to detail. You can also get the haynes or chilton dummie book and it'll walk you through the steps with perty pics. That's what I do. Good luck
  12. Sep 26, 2011 at 12:16 AM
    wrxRome
    Brandon
    Or YouTube it being done on a Tacoma. U joints are cheap too like 30 bucks each
  13. Sep 26, 2011 at 12:31 AM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    If you are not so mechanically inclined... i'd take it to a shop. However, this is a very easy job. Here is what you will need in order to do it quickly:
    Pliers
    Torch
    Hammer and Wooden mallet
    Necessary wrenches
    Grease gun
    1. Check which U-Joints are bad. Note: Get Japanese made U-Joints.
    2. Take out the whole assembly.
    3. Set it somewhere and take out the clips from the U-Joints that need replacing
    4. Heat up the U-Joint a bit and with some type of small hard tubing, hammer the U-Joint to one side. Take out the end that comes out and repeat with another side. Then the U-Joint should come out. Take out the next 2 tips with the same heat/hammer technique.
    5. From now on be careful with you new U-Joint. Do not drop them or open them constantly. They have small pins inside that you need to not damage.
    6. Take out caps from 2 ends and with a wooden mallet, put the U-Joint inside and hammer the tips into the drive shaft flange. You should have 2 tips secured. Now repeat with the next 2.
    7. Put all clips in.
    8. Grease them will a bit of grease comes out.
    9. Reassemble assembly in the same way it was at the beginning.
    Note: Pressing the U-Joints with a small press will be really hard, hence why the torch and hammer method. You would need a decent press for this, which most of us will not have at home.
    I've changed plenty of these on Tacoma's and so far so good. It real easy and fast once you get it down.
    I'm not a mechanic by trade, so take this for what it's worth.
  14. Sep 26, 2011 at 1:32 PM
    1990wade
    Wade
    Danville, Georgia
    Well me and my dad are doing this sometime in the middle of next week...So whats the best brand of U joints to get and what store has the best price??
  15. Sep 26, 2011 at 2:30 PM
    1990wade
    Wade
    Danville, Georgia
    Or is it best to get the part from a dealership
  16. Sep 26, 2011 at 3:00 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  17. Sep 27, 2011 at 1:01 PM
    1990wade
    Wade
    Danville, Georgia
    Geez i gotta get new U joints, oil change, fix my overhead temp gauge, then to top it off my driver front tire has a small leak in it..Next week should be busy fixing these things lol..Also gonna fix them damn squeaky leafs..Sorry just had to rant :p
  18. Sep 27, 2011 at 1:10 PM
    cc350
    cc350 Retired Member
    Sounds like a couple hours of good ole bonding time :)
    NAPA for Cheapa...
  19. Sep 27, 2011 at 8:44 PM
    SbRsH11
    SbRsH11 Member
    Virginia
    06 TRD Sport
    If it's not your u-joints, I'd definitely look at the carrier bearing... Mine went out before on my '01... caused a vibration upon acceleration and a low drone sound... Good luck!
  20. Sep 28, 2011 at 1:05 PM
    1990wade
    Wade
    Danville, Georgia
