What's this sound?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfetty, Jan 4, 2009.
  1. Jan 4, 2009 at 6:02 AM
    sfetty
    sfetty [OP] Member
    WV
    09 Tacoma Dbl Cab 6ft bed
    I have a 2009 Tacoma DBL Cab 4X4 V6 L/B. Everytime I start my truck and put it into gear, a sound that I can only describe as sounding like an air wrench going off for a second comes from the front passengers side of the truck. It sounds like it is coming from underneath the truck. I thought it sounded like the rear view camera was activating itself. This only happens each time the truck is shut off and started and put into gear. I am sure it is supposed to happen, but I would like to know what the sound is. The dealership that I bought it from didn't give me a satisfactory answer. I suggested it sounded like the rear camera was focusing itself and they agreed. Sounds like it may be a case of the blind leading the blind. Does anyone on this forum have any ideas as to what that sound may be and do other 09 Tacoma owners experience the same noise when they start their truck and put it into gear?:confused:
  2. Jan 4, 2009 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    My truck did that for a while when it was new. Im not sure when, but it eventually went away. It doesnt make the sound anymore.
  3. Jan 4, 2009 at 6:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You might be referring to the ABS system check. It's a sound that happens everytime you put the truck in gear and start moving.
  4. Jan 4, 2009 at 6:27 AM
    sfetty
    sfetty [OP] Member
    WV
    That sounds like that could be the sound I am hearing. I am sure it is a sound that is supposed to happen and the ABS system check would be a likely culprit. Thankyou!
  5. Jan 4, 2009 at 11:51 AM
    sfetty
    sfetty [OP] Member
    WV
    You would think that after all those years of marriage. I would be able to tune out every sound known to man.:D
  6. Jan 4, 2009 at 1:42 PM
    09silvertaco
    09silvertaco Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    ABS self check, both my tacoma and 4runner do it.
  7. Jan 4, 2009 at 1:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Dang 09's come with a camera unit for the rear?:confused:
  8. Jan 4, 2009 at 1:45 PM
    09silvertaco
    Massachusetts
    sure do WW. though im so used the driving w/my mirrors i dont find myself using it much.
  9. Jan 4, 2009 at 1:49 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Dang I didn't know that! Is that a standard option? Also, where is the monitor located?
  10. Jan 4, 2009 at 1:54 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey since were are on sounds. Is it normal for our trucks to make a little ticking sound from the engine while it is running?:confused:
  11. Jan 4, 2009 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  12. Jan 4, 2009 at 2:17 PM
    09silvertaco
    Massachusetts
    monitor is in the rearview mirror. and yes, that tick is perfectly normal.
  13. Jan 4, 2009 at 2:20 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Wow, monitor on the rear view mirror! That's sweet. Dang I'm jealous!!:drool:
  14. Jan 4, 2009 at 3:02 PM
    sfetty
    sfetty [OP] Member
    WV
    I use the monitor to see what I am running over.:D WW, my brother is the Fire Chief for the city of Morgantown, WV. I have a lot of respect for firefighters!
  15. Jan 4, 2009 at 3:04 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Cool! Props go to him!!! Is he a full timer or volunteer?
  16. Jan 4, 2009 at 3:07 PM
    sfetty
    sfetty [OP] Member
    WV
    Full time. 33 years as a firefighter. Probably gonna retire within a year.
  17. Jan 4, 2009 at 3:23 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez!! That is a long time!!! Well good for him!!!;)
