What's this sound?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Sep 13, 2016.
  1. Sep 13, 2016 at 4:10 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
  2. Sep 13, 2016 at 5:49 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wtf??? I've never heard anything like that. Does the same noise while it's moving as well?
  3. Sep 13, 2016 at 5:51 PM
    cruiserguy
    Elijah
    SEKS
    Maybe a bushing not tightened up all the way? Someone there to help you pinpoint where exactly it's coming from(while you turn wheel, they lay down and listen, vice versa)?
  4. Sep 13, 2016 at 5:53 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    The noise is from before or after instalation of ball joint and rack?
  5. Sep 13, 2016 at 6:24 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    So loud it's hard to pinpoint. Turning heads as I'm driving down the street. Progressively got worse and worse. Just had it towed home. Also, I can't turn all the way to the right. Only can turn the wheel like one full turn.
  6. Sep 13, 2016 at 6:42 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Faulty ball joint or steering rack..? Get it up in the air and start checking things out.
    Actually it shouldnt be to hard to pinpoint on the ground. Get a buddy to get down under and listen around while you turn the wheel.
  7. Sep 13, 2016 at 8:42 PM
    Roadeater
    Kennesaw, Ga
    Tie rods??
  8. Sep 13, 2016 at 8:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    How long ago did you lube the uniballs, and what fluid did you use? My UCA uniballs actually make a similar sound when they haven't been lubed for a while.
  9. Sep 13, 2016 at 9:20 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Teflon silicone, they've only been on the truck a week. Lubed them probably 3 times since they've been on because the noise has been getting worse.
  10. Sep 13, 2016 at 9:22 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    There's your problem.
  11. Sep 13, 2016 at 9:27 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Lift the front end. Get some tension off. Might be able to hear it better.
  12. Sep 13, 2016 at 9:29 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Tie rods are new as well, unless one is faulty. The steering rack bushings have a crazy amount of play as well, but the sound really doesn't sound like it's coming from any bushings.
  13. Sep 13, 2016 at 9:30 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Will do. Had to tow it home about 60 miles. Gotta get ready for my shift so won't be able to work on it till sat.
  14. Sep 13, 2016 at 9:33 PM
    ImplicitlyAlberta
    David
    edmonton
    If the rack has play id say thats your issue.
  15. Sep 13, 2016 at 9:53 PM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Maybe a CV joint with mud in it?
  16. Sep 13, 2016 at 10:59 PM
    cruiserguy
    Elijah
    SEKS
  17. Sep 13, 2016 at 11:04 PM
    97handmedown
    97handmedown Well-Known Member
    Tyson
    1997 Tacoma 4x4 Single Cab
    3", wheels, tires, old man seat covers
    I'm guessing ball joint. Disconnect the outer tie rod from the knuckle on that side and jack the truck up. Push and pull the wheel back and forth and see if you hear it. Sounds like a DRY ball joint to me.
  18. Sep 14, 2016 at 6:11 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Would of of those automotive stethoscope things help? I know it's loud as shit but might pinpoint it...never used one
  19. Sep 14, 2016 at 6:21 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Yep, sounds exactly like a dry aftermarket lower ball joint, a new OEM would not to that.
    lonzorizo[OP] likes this.
  20. Sep 17, 2016 at 3:57 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Unbolted the outer tie rod and moved the wheel by hand. Sounded like lbj. Removed the lbj and spun the rotor/spindle and it still makes the screech and it's hard to turn. The driver side that's connected to the tie rod makes the sound as well.
    So that leaves me with the uniball as the last piece. Why are they making the noise and not spinning easily? The (shitty) shop did the install of the uca's, could they have somehow assembled them wrong? Seems pretty straight forward to put them together. If I take the uniball apart what should I be looking for?
