What's this spark plug telling me?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Apr 1, 2021.
  1. Apr 3, 2021 at 12:12 PM
    #61
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Some cylinders take more time to build up compression usually due to normal wear; although like Lefthook mentioned this could be an indication of problems/leaks versus other cylinders. And without your foot on the gas pedal, the butterfly valve on the throttle body is closed, which limits the amount of air (and as a result, compression) the cylinders can produce.
    Those numbers look good to me.
  2. Apr 3, 2021 at 12:21 PM
    #62
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    So what can I do to help keep or make the pistons & cylinders happy?
    I was going to do a seafoam type thing through the pvc valve. Something I have never done & after seeing all the carbon buildup in the IAC, I imagine that’s not the only place it resides.
    Also, what to make if the gas in the oil & lean conditions?
    I did order some valve cover & spark plug gaskets.
  3. Apr 3, 2021 at 12:56 PM
    #63
    Lefthook
    Lefthook Well-Known Member
    New jersey
    2014 DCLB
    Tonneau cover
    The readings look good to me also. Put it back together and drive it the way that it is. If you feel any major problem, tackle that if needed. Drive it and give it a chance. You cleaned the IAC, hopefully have spark plugs nice and tight to torque spec and the crush washer is sealing. Remember, when you go to the doctor, he gives you medicine and will see if there is an improvement. He usually won't throw 5 medicines at you to see what heals you. It is better to do one step at a time. Do not do 5 things at once because you will never know what may have fixed the problem if it should happen again. Remember- diagnose like a MD.
    Kristi with a K[OP] likes this.
  4. Apr 3, 2021 at 1:14 PM
    #64
    Kristi with a K
    Western MA
    I hear you. I just have neglected the truck for so long. A lot of it due to ignorance. Not an excuse. Simply fact. So there are many things I am sure I have not done as a routine type preventative engine type thing beyond spark plugs, oil, atf, gear oil.... I mean little by little I am picking up on things on TW. Hoses, IAC.... I just don’t want to wait for a problem to get me to the learning. I am not really the “if it ain’t broke, don’t fix it type”, especially if by some simple, or even not so simple, maintenance you can help it not get to the broke point.
  5. Apr 3, 2021 at 9:25 PM
    #65
    patos tacoma
    patos tacoma Well-Known Member
    I really would encourage to do the BF fuel injector treatment by a reputable garage for the carbon buildup......I did everything up to that, but after seeing how dirty the “other side of the throttle body was, I did it.....
    When the dealer cleans the throttle body, they only clean one side by they don’t want to take it off.
  6. Apr 4, 2021 at 6:39 AM
    #66
    Kristi with a K
    Western MA
    I did a search for BF fuel injector treatment & not much came up. Did you mean BG? & if so, why didn't you do it yourself?
  7. Apr 4, 2021 at 6:41 AM
    #67
    Kristi with a K
    Western MA
    & no worries. I am heading advice to wait 'n watch before the next move....
  8. Apr 4, 2021 at 8:36 AM
    #68
    patos tacoma
    Yes BG, thanks
    I let the garage do it for 2 reasons........1) it’s delivered under pressure 2) for the cost @$125, not worth the messy cleanup and professionally done.....
    Will probably do it for my BMW M2, the dealer wants $375 for doing the same things.....
    I’m sure there’s a DIY BG treatment, think I saw videos on it, that less expensive, you can try that too and get some if not all the carbon gone, BUT I wanted the FULL effect.
