What's to much?
Discussion in '4 Cylinder' started by Tulot Tech, Oct 2, 2011.
  1. Oct 2, 2011 at 3:28 PM
    Tulot Tech
    Tulot Tech [OP] Well-Known Member
    Justin
    Trumann, AR
    2017 TRDOR DCSB, 4x4 6 Speed Manual
    Is plasti-dip a mod?
    I'm thinking about going with a 3" lift and swapping my stock 245/75/R16's for some after market -12 offset 17 inch rims with some nitto 265 all terrains.
    I'm in 2012 Access Cab, pretty stock with a I4, 5 speed manual. Do you think I'll be putting a significant amount of more strain on the engine/truck?
  2. Oct 2, 2011 at 3:39 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You'll be perfectly fine running that tire size. Your truck will feel more sluggish, but that's something that new gears can correct. You're definitely not over stressing the components. Yes, it is more stress than stock...but it's a negligible difference.
  3. Oct 2, 2011 at 7:08 PM
    Tulot Tech
    Justin
    Trumann, AR
    thanks guys
  4. Oct 2, 2011 at 7:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The -12 offset likely means they are 9" wide wheels, which sometimes are too wide for 265s. Check the tire manufacturers guidelines.
