What's up with this POS engine oil dipstick?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Sep 19, 2011.
  1. Sep 20, 2011 at 7:50 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    x2
  2. Sep 20, 2011 at 8:03 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I check mine before it's been driven that day. Seems to be no problem then. If I am on a trip and feel the need to check it at a gas station, that's when it's hard to read.
  3. Sep 20, 2011 at 8:07 AM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    when theirs a problem, plasti dip is the solution
  4. Sep 21, 2011 at 12:06 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    :bowdown:
  5. Sep 21, 2011 at 12:22 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Ok fine, don't be the guinea pig for the dip.... You could heat shrink it, make it kind of long and it should be able to withstand the heat, and rubber should take oil fine as it is a petroleum product. You could also sand it and paint it with an engine paint as it should handle heat and oil. To see how well it will work before making it permanent clean the dipstick very good to remove the oil residue, put masking tape on the end, then paint the masking tape. DO NOT leave this on for long as it will eventually fall off and can block the oil pickup.
  6. Sep 21, 2011 at 12:57 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    2nd gen owners lol
  7. Sep 21, 2011 at 12:58 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    Buncha complaining assholes if you ask me.
  8. Sep 21, 2011 at 1:15 AM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Dumb suffices sir ;p
  9. Sep 21, 2011 at 1:17 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    If it's really, really bad.
    -Check oil level with dipstick.
    -Hold dipstick flat and level.
    -Run thumb slowly over the bottom of dipstick.
    -Should see oil buildup between thumb and stick as you move thumb across the end of the dipstick.
  10. Sep 21, 2011 at 1:22 AM
    DV88
    DV88 Active Member
    Dustin
    Redding
    Rock Rails Rear Bumper in Progress Skid Plates in Progress
    Umm... what is going on?
  11. Sep 21, 2011 at 4:50 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    Some people need glasses but they don't want to admit it:)
  12. Sep 21, 2011 at 8:48 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Ha ha. I got a funny visual aid on my oil level check last night. I was at the gas station and it was already dark, I was reinserting my dipstick. Suddenly, there's a spark, a flash, and the end of the dipstick BURSTS INTO FLAME illuminating the re-insertion point! :eek::eek::eek:
    WTF???
    So I pulled it out and smothered the flame (think "candle") with the rag I used to wipe the dipstick down. How the hell did that happen??
    Turns out my positive battery terminal won't hold it's plastic cover in place because of all the extra wires and fat winch cable coming off of it. So as I was reinserting the dipstick, it touched the positive terminal and grounded against the insertion tube completing the circuit, creating a spark and igniting the oil on the dipstick.
    Just a little something to keep an eye out for if your positive terminal is uncovered....:eek:
  13. Sep 21, 2011 at 8:51 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Fuck condoms, I'm going to plastidip my wiener.
  14. Sep 21, 2011 at 4:53 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    :rofl:
  15. Sep 21, 2011 at 10:06 PM
    #35
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    If you're a little over-filled or a little under-filled... It's fine.
    You're not going to hurt nothing!:homer:
  16. Sep 21, 2011 at 10:13 PM
    #36
    80s toysport
    80s toysport Well-Known Member
    Nikolai (Nik)
    kansas city, ks
    09 DC TRD off road
    Camper, nerf bars, visors, hood bug gaurd, ABS killswitch, bed light
    Why dont you just take a punch to it. Makes a few small indentions. Thas what i did to my old sienna van. It even hold a little oil in it to see. Havent tried it on my taco yet but will tomorrow :)
