What's ur choice for undercoating?
Discussion in '4th Gen. Tacomas (2024+)' started by DoritoDon, Jan 1, 2025.
  1. Jan 1, 2025 at 4:49 PM
    DoritoDon
    DoritoDon [OP] New Member
    2024 tacoma sr
    Looking for recommendations for undercoating new Tacoma. Fluid film or woolwax seem to be the best options.. but I don't have a sprayer or compressor..How many spray bottles would do the underside? And any tips would be great .thanks, Don
  2. Jan 1, 2025 at 5:13 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    LPS3 or Fluid Film. Buy a case.
  3. Jan 1, 2025 at 5:18 PM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I like WoolWax best but BP Blaster Surface Shield is awesome and can be found in a can. There is a YouTuber that compared it to others and it outlasted all of them by a decent margin.
  4. Jan 2, 2025 at 6:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    For DIY spraying, CRC Marine, Cosmoline, Amsoil HDMP work the best. Takes about 6 cans to do the whole underside if you're thorough. Lasts several years and doesn't cause dirt to stick.
    If you don't feel like crawling on the garage floor and want to get it sprayed at a shop, then Fluid Film, Rust Check, Woolwax, etc. are all similar. The care and thoroughness of the technician becomes a bigger factor.
    Black97v6MT likes this.
  5. Jan 2, 2025 at 9:00 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    I only just started using Fluid Film on things myself, so I can’t weigh in on how good it might be for undercoating. I can, however, tell you that it’s going to make whatever you put it on smell like wet sheep for several days.
    I had read that Wool Wax performs the same but doesn’t stink so bad.
    SilverBulletII and usmc2msu like this.
  6. Jan 4, 2025 at 11:09 AM
    fitsofrage88
    fitsofrage88 Well-Known Member
    ATX
    fluid film….
  7. Jan 4, 2025 at 11:24 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...if you deal with salt and salt water making its way into everything, and only treat the frame, that's a whole lot of truck you are not treating.
    ...i don't remember what i paid for it initially, but my annual krowned re-sprays are $100.00, or about $108.00 ish with tax, annually, and after every fall treatment, i'll still see dips of that stuff oozing out of the lower doors and tailgate when it starts to get hot out.
    skiergd011013 and Black97v6MT like this.
  8. Jan 4, 2025 at 11:35 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    my personal take:
    the hard waxes are better at keeping the contaminates out, but the area to be treated needs to be 100% clean and dry or you could be sealing the problem in
    the oils seem better at displacing/sealing the contaminates off the surface but do not hold up as long
  9. Mar 3, 2025 at 3:29 AM
    LanceIdaho
    LanceIdaho New Member
    Lance
    2012 Tacoma
    Hey Gents, looking at Fluid Film vs LPS3. Both in 11oz spray can. LPS3 twice the price. Is it that much better than Fluid Film? Thanks!
  10. Mar 3, 2025 at 3:57 AM
    AvalonTaco
    AvalonTaco Falken Sales Rep.
    Joe
    Cabin in the woods
    2019 Super White DCSB OR
    Working on a lien delete for my title…..
    Two years of Fluid Film, switched to Woolwax, better application, not as runny and smells better.
    My .01
  11. Mar 3, 2025 at 4:02 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Applying woolwax isnt just for shops. Assuming you have an air compressor it can be done for about $100
    https://www.woolwaxusa.com/Woolwax-Standard-Spray-Gun-With-extension-wand-_p_30.html
    https://www.woolwaxusa.com/Woolwax-...w-clear-Black-or-Gray-Free-Shipping_p_25.html
    Stuck in VT likes this.
  12. Mar 3, 2025 at 4:25 AM
    LanceIdaho
    Lance
    2012 Tacoma
    Hey AvalonTaco & TacoTuesday603, Thanks. This is helpful. I have a couple smallish areas around the receiver hitch that I hit with a wire wheel on a angle grinder. Took off the surface rust and the paint. Would you recommend re-primer and painting, then Wool Wax? Also I have anti seize on exposed threads of the bolts, will the Wool Wax stick to that? Thanks
  13. Mar 3, 2025 at 4:37 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Depending on if its perfectly clean or not I would just hit it with rustomeoum rust reformer then WW.
    As for antisieze, I use it all the time and have WW over it and it hasnt caused any issues.
  14. Mar 3, 2025 at 5:35 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Boeshield T-9 anybody?
  15. Mar 3, 2025 at 5:36 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I use that on my coilovers. Works well.
    Black97v6MT[QUOTED] likes this.
  16. Mar 3, 2025 at 5:41 AM
    Black97v6MT
    iMA0
    tacoLand USA
    How do you tell if it needs a respray
    Since it is so clear and doesn't attract dirt that I can tell
  17. Mar 3, 2025 at 5:43 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    NHOU
  18. Mar 3, 2025 at 5:43 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I just do it every time the wheel is off. Just a quick spray.
    For the whole truck I dont really reapply anything, I just have a routine every fall that I do and I call it good enough.
  19. Mar 3, 2025 at 7:45 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    It's a super beginner friendly process.
    Assuming you started with nothing, you went into undercoating with terminator rules, your all in cost will be at most $350. And that equipment is fully reusable year after year.
    I did it with the most low budget 2.6 CFM pancake air compressor, 3 hours start to finish net of cleanup time. Considering that the going rate my area is $400 for this work, I think I did pretty well.
    That said, if I was doing a brand new truck again that was clean, I would use CRC marine protectant a.k.a. Cosmoline.
  20. Mar 4, 2025 at 6:15 AM
    Peg Leg
    Peg Leg Active Member
    Chuck
    Fluid Film, 5 galls at a time, applied once a year with a high pressure gun
