What's with the 3rd gen Tacoma V6 needing spark plug replacement at 60k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainjim, Mar 20, 2024.
  1. Mar 20, 2024 at 7:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Timing chain cover and rear coolant pipe leaks are abnormal events. The vacuum pump replacement is scheduled maintenance, in the books at 100k intervals. It's akin to engines needing timing belt replacement in the previous century.
    OR and Pro with electronic brake boosters have a blanking plate where the pump would be.
    OZ TRD likes this.
  2. Mar 20, 2024 at 7:15 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Yep, I've examined mine a few times and so far at 80K I'm good. After skimming over that TSB, that doesn't look bad at all. Says it will throw a code but it seems that by that time it may be too late and could be dangerous. Thank you for the heads up.
  3. Mar 20, 2024 at 7:33 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    Funny, I did mine at 55k and indeed the two front plugs on the passenger side were ever so slightly too loose from the factory.
  4. Mar 20, 2024 at 7:34 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Interesting. I can see that angle in the argument.
    On 2gr-fks, it is not clear why they advise for 60k. Toyota's other d4s with Atkinson engine have 120K replacement interval.
  5. Mar 20, 2024 at 8:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Would you like to know about the retreaded tire industry supplying major airlines around the world? :laugh:
    Malvolio likes this.
  6. Apr 10, 2024 at 5:32 AM
    jjnicolas
    jjnicolas Well-Known Member
    JJ
    NorCal
    19 trd off road DCLB
    19 taco here. At 60k I had longer than usual cranking. Did spark plugs and found 2 plugs hand tight and one loose. So yea, at least check them.
    WilliamJames and Stevie17 like this.
  7. Apr 10, 2024 at 6:29 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The reason for recommended plug replacement at 60k on the 2GR-FKS is the higher cylinder pressures related to DI. Higher cylinder pressure is harder on plugs. That said, I have 76K on mine and will wait to 80K before replacing. I had a 2GR-FE (no DI) and they had 120k replacement interval. Ran those plugs to 185k with no issues.
    WilliamJames, Stevie17 and 908tacoma like this.
  8. Apr 10, 2024 at 6:35 AM
    Vlady
    Issy, WA
    Toyota's 2.5L engine comes with d4s and 120k spark replacement schedule
  9. Apr 10, 2024 at 6:54 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    Which one? 2AR-FE is 120K interval but has no DI. 2AR-FSE and 2AR-FXE are DI but have 60K plug change intervals.
  10. Apr 10, 2024 at 7:02 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    I thought i was the only one that thought the same thing lol
    Dennis K and maxmk8[QUOTED] like this.
  11. Apr 10, 2024 at 7:02 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    this
  12. Apr 10, 2024 at 7:09 AM
    Vlady
    Issy, WA
    There is only one as far as I know -A25A-FXS
  13. Apr 10, 2024 at 7:18 AM
    jcat2435
    jcat2435 Active Member
    PNW
    2017 TRD Sport ACLB MT Quicksand
    OVTune 2.0 SFOB Premium + edits OV Catted Dump Tubes 4.88 gears F/R ARB Lockers 255/85 r16 Cooper ST Maxx Method 701 16x8" King 2.5 Mid Travel Dirt King Uniball Heimed UCAs Dirt King Uniball LCAs Deaver U402 stage 2 Hammer Hangers FJ Manual T-Case with twin sticks ADD Delete Core Shifter ADM RCI Skids + Sliders
    I replaced mine at 70k. Wish I had done it sooner - the #5 plug was barely finger tight and there was a lot of buildup on the coil pack. For the price and time it takes to replace them, I’d say it’s worth it just to have piece of mind that all your cylinders are happy.
    MR E30 and Stevie17 like this.
  14. Apr 10, 2024 at 7:20 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My mileage changed for the better - for all of three weeks when I changed the plugs as recommended. Whoopee.......... not worth disturbing the wiring.
  15. Apr 10, 2024 at 7:22 AM
    #35
    Arries289
    Arries289 Yo!
    Franklin TN
    There are many iterations of their 2.5L engines going back just 10 years. The A25A-FXS is a hybrid only engine. That might have something to do with the 120K interval. But, all the standard non-hybrid DI engines have 60K intervals, as far as I am aware.
  16. Apr 10, 2024 at 7:39 AM
    #36
    Vlady
    Issy, WA
    "..If your Camry is equipped with the 2.5L 4-cylinder engine (A25A-FKS), you can wait until this 144-month/120,000-mile mark to replace your spark plugs. Drivers with this engine should also inspect their vacuum pump for the brake booster at this time, replacing if necessary..."
  17. Apr 10, 2024 at 8:00 AM
    #37
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    The helper in Goonies immediately came to mind.
    908tacoma and joeR6 like this.
  18. Apr 10, 2024 at 8:09 AM
    #38
    Clearwater Bill
    Billy
    Largo Florida
    Well, its twice as long as ealier generations, so there's that to appreciate.
    Shop other places. Only plugs are needed. Some online skanks want to supersize everything. ;)
    Looking for something other than what's listed in the owners manual? Many of us do transmission drain and fills around 60k. I don't think that's in the book.
    :hattip:
  19. Apr 11, 2024 at 6:14 AM
    #39
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    don’t mix the drugs!
  20. Jul 29, 2024 at 1:51 PM
    #40
    Dennis K
    Dennis K Member
    Dennis
    2020 TRD Sport
    Yeah, I was a bit shocked when the dealer said your plugs are due to be changed. Thanks but I got that. I had it in for the 60k service. Last time there for their work. They raped me for the tranny and differential fluid changes.
