What's with the 3rd gen Tacoma V6 needing spark plug replacement at 60k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainjim, Mar 20, 2024.
  1. May 5, 2025 at 2:29 PM
    #41
    Spicietaco
    Spicietaco Well-Known Member
    2020 dblc trd off rd 4x4
    Wheels, tires, lift, shocks, fender flares
    My 2020 has 87k on it. No missing or skipping or reduced gas mileage yet. I'm waiting until 100k.
    Mas Olas[QUOTED] likes this.
  2. May 5, 2025 at 5:12 PM
    #42
    Williston
    Williston Sorta Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Re: Fakes?: Buy them from a dealer. Some dealers sell them through Ebay and the like. I purchase them from a local dealer near me for around $6.00 each, and the last time with free shipping or free pickup at their parts counter. Check several dealers for the best price as it varies among them. 60,000 is a good guideline for replacing them. (you don't need to buy new coils) I like being able to inspect them at that interval. Leaving them in for 100,000+ or more risks seized threads. (IMO)
    https://autoparts.toyota.com/
    #42
  3. May 5, 2025 at 5:42 PM
    #43
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    ^ True!
    FWIW: My '66 Mustang called for Oil/Filter, Points and condenser, carb adjustment, clean PCV, adjust fan belt, plus plugs every 6k
    Now my souped up '68 Charger w/ a 440; that thing could foul a set of plugs with just a few instances of stepping on it before it was warmed all the way up. Best case scenario, they had to be changed every ~3-5k or so (Of course in the 90's those Autolights were only ~$3-4 each)
  4. May 5, 2025 at 6:06 PM
    #44
    Clearwater Bill
    Billy
    Largo Florida
    Changed plugs in a 69 RA IV Judge every week. Running 2 steps colder though, and every Friday night drags.
    shakerhood and Speedbird[QUOTED] like this.
  5. May 5, 2025 at 6:28 PM
    #45
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    This is not correct. There are 2 different ABS modules on the 3rd gen. One requires vacuum from the vacuum pump (SR/SR5/Sport) the other (OR/PRO) doesn't require the vacuum pump.
    Speedbird likes this.
  6. May 5, 2025 at 6:36 PM
    #46
    OldSchlPunk
    Rich
    East Central Wisco
    Where did you get that info? I don't believe it at all. The spark plugs are simple copper core plugs that become less effective after 60k miles because the electrode starts burning down, creating a larger gap. A larger gap takes more current to fire, which will shorten the life of your coils.
    Some reference reading: https://oards.com/types-spark-plugs/
    Canadian Caber likes this.
  7. May 5, 2025 at 6:44 PM
    #47
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Which part of what I said was not correct? Previous naturally aspirated Toyota engines like the 1GR-FE in the 2nd gen Tacoma didn't have a vacuum pump; the intake manifold vacuum alone was sufficient to power the brakes on SR5/TRD Sport models. Also, you need to read my post in context. I was replying to TacoSupremo19, who has a TRD Sport.
  8. May 5, 2025 at 6:47 PM
    #48
    OldSchlPunk
    Rich
    East Central Wisco
    Manifold vacuum is all the OR and Pro models get, and work fine. So, the 2GR creates enough intake vacuum. It's the ABS module in the other trims that need boosted vacuum. There are two systems in the 3rd gen.
    https://www.tacomaworld.com/threads/18-trd-vacuum-pump-vs-non-vac-pump-motors.759101/ See post #4.
  9. May 5, 2025 at 6:51 PM
    #49
    OldSchlPunk
    Rich
    East Central Wisco
    To expand on this: A normally aspirated 10.2/1 CR isn't going to create terribly high cylinder pressure. I've raced engines with CRs around 14/1 with copper core plugs and never had a plug failure.
  10. May 5, 2025 at 6:51 PM
    #50
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Wrong. Look at your intake manifold. The vacuum port that would connect to the booster on SR5/Sport models is capped off on OR/Pro. The OR/Pro's braking power comes from the electric motor only; it doesn't rely on manifold vacuum at all. Educate yourself on your truck before misinforming others.
    b_r_o likes this.
  11. May 5, 2025 at 6:57 PM
    #51
    OldSchlPunk
    Rich
    East Central Wisco
    I misread the post I referred to and didn't think through what I typed. I do know this because I do know the OR doesn't have a vacuum booster, it works with the hydraulic ABS module. :frusty: Where's that crow...
  12. May 6, 2025 at 9:45 AM
    #52
    danielgonzzz
    danielgonzzz Well-Known Member
    Daniel
    2019 Tacoma TRD Sport 4x4
    Stawk as FUCK!
    Do it ASAP! 3 of my 6 were LOOSE, not snug, not hand tight. LOOSE! As in out the socket with extension into the plug hole and was able to feel the spark shimming. Thank god I did it at 50k otherwise I fear I’d have part of a plug bouncing in my combustion chamber.
  13. May 7, 2025 at 8:04 AM
    #53
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    I was actually watching, I think car care nut may have talked about it. If you’re a low mileage driver, that would be me, and you don’t hit 60k at about 5 years, either do it anyway or at a minimum break them loose and retorque them..accomplishes obviously making sure they are tight like they’re supposed to but also ensures they’re not seized in there when you do change them down the road. I just changed since I had a wrench on them anyway, but indeed 2 were noticeably looser than the others
  14. May 7, 2025 at 12:52 PM
    #54
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    First off, the maintenance schedule has nothing to do with 'failed' plugs. Toyota's concern is driveability, fuel efficiency and emissions. The electrodes wear faster on any DI engine - that is a fact - look it up. The 2GR-FKS is not a 60's high compression engine and you cannot make that comparison. It runs much leaner with up to 14.2:1 compression, as determined and allowed by the ECU. Those conditions reduce the life of the plug electrode.
  15. May 7, 2025 at 1:35 PM
    #55
    OldSchlPunk
    Rich
    East Central Wisco
    The concepts haven't changed. Compression is compression. A/F ratios are still A/F ratios. Doesn't matter if it's carbureted or some kind of FI. The factory claims 10.2:1 compression ratio. As a naturally aspirated engine, there is no way that's going to significantly change, either through valve timing or the flapper valve. There is only so much air that can pass the valves without being forced.
    Burned electrodes are 'failed' plugs, whether they're misfiring yet or not. Burned electrodes won't fire as cleanly, affecting the burn of the fuel mixture. Improperly burned fuel affects emissions and fuel efficiency. Electric sparking is what burns electrodes.
    Yes, the maintenance schedule has a lot to do with this. Toyota knows this. That is why they specify 60k spark plug life. They are the ones building the engines to pass emissions tests over a wide lifetime. They are the ones that spend hundreds of hours on the dyno testing any and all variables the engine is going to face.
    edit: '60s Detroit didn't really care about cylinder efficiency. They knew the concepts, but didn't have to worry about it. Today, manufacturers have to pay attention to every last detail, including oil pressure and viscosity, to get maximum efficiency.
  16. May 21, 2025 at 8:31 AM
    #56
    vpitaco
    vpitaco New Member
    2018 Tacoma TRD Off Road
    I was just quoted an absurd $800 for spark plug replacement because my truck is 7 years old (2018 with only 30,000mi). They mentioned it should be done every 72 months (6 years) which I assume would be normal mileage for anyone else. Would my spark plugs still be ok for another few years in my case? It obviously does not get driven a lot.
  17. Jun 2, 2025 at 10:36 AM
    #57
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Yes they would.
  18. Jun 2, 2025 at 6:41 PM
    #58
    Speedbird
    Fort Couch
    2017 TRD-OR
    Agreed, not necessary... HOWEVER, if you have a tad mechanical ability and a few sockets, extensions and picks; at 6-7 years old, I would crack them loose and retorque... BUT, while you're in there it would only take another 5 seconds each to install new ones... I want to say 6 plugs from the dealer were ~$225, so if you don't mind spending that kind money early do that.
  19. Jun 2, 2025 at 6:57 PM
    #59
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yikes, those are 15 to 18 per plug. Day light robbery
  20. Jun 3, 2025 at 4:12 PM
    #60
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I did mine at 60k per the book and my shop manager asked why because they are 100k plugs.
