WHATS WITH THE A/C
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Oct 16, 2010.
  1. Oct 16, 2010 at 12:36 PM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Why does the A/C come on when I put the defrost on, Its starting to piss me off, now that its getting colder I like to have the defrost on with heat.
  2. Oct 16, 2010 at 12:45 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Almost every car I've ever owned is set up that way. The cold air reduces condensation on the window. Turn the temperature knob to a hotter setting.
  3. Oct 16, 2010 at 12:45 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    the condensor takes the water out of the air to make defrost work better.
    iturn the knob all the way right to defrost, take the knob off, and turn it one more click right and see what happens.
  4. Oct 16, 2010 at 12:46 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
  5. Oct 16, 2010 at 12:55 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I thought someone had a write-up for 1st Gen on there, sorry couldn't find anything. I suppose you could do the same thing, just would have to follow the diagrams later in that thread.
    Maybe someone can post up a write-up for ya.....
  6. Oct 16, 2010 at 12:57 PM
    Madjik_Man
    Boulder County
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    I don't get why you'd do that mod.
    The whole point of running the defrost with the AC is so it defrosts your windshield.
  7. Oct 16, 2010 at 1:11 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
  8. Oct 16, 2010 at 1:16 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Lol I know...it cracks me up when I read these. The AC takes the humidity out of the air. People think for some reason with the heat on and AC on, the air is gonna be cold. Wrong. I run my AC all winter with my heat. I actually rarely even use my defroster because heat w/ AC actually keeps the windows from fogging.
    Car companies wouldn't make cars do this is there wasn't a purpose behind it.
  9. Oct 16, 2010 at 9:49 PM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    There is definitely a purpose behind it, but it depends on where you live. Some places do have a lot of humidity in the air when it is cold, and the defroster does need the dehumidification of the AC system. But in some areas the cold is usually a "dry cold", and the air really doesn't need any dehumidification.
    That said, I usually let my cars still run the AC with the defrost, partially just because it means the AC gets run periodically, even in the winter - it is bad for the compressor to sit unused for a long period of time, it should get cranked occasionally to keep the oil circulated.
    -Sam
