Whats with Toyota limiting 12Vdc power outlets to 10A ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016Tacoman, Oct 14, 2017.
  1. Oct 14, 2017 at 3:20 PM
    2016Tacoman
    2016Tacoman [OP] Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Tacoma's, Tundra's, Camry's all have the DC power outlets limited to 10A.
    Any good portable air compressor such as a Viair needs 15A.
    Seems like if Toyota used 18 gauge wire, it would be good for 15A easily.
    https://www.tessco.com/yts/industry/products/itm/automotive/get_wired.html
    I could swap the fuse but then if something happened they might decline the warranty.
    Of course you could run a power block and other options.
    What did you do ? Buy a 10A portable compressor or rewire ?
  2. Oct 14, 2017 at 3:27 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Get one with alligator clips powered off the battery.
    Paul631 and Shellshock like this.
  3. Oct 14, 2017 at 3:28 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I have a craftsman pump from sears that works great off the outlet
  4. Oct 14, 2017 at 4:35 PM
    Shellshock
    Iowa
  5. Oct 14, 2017 at 5:25 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    As does every other vehicle.
    That's a Viair / (and other) 12v compressor issue, not the car manufacturer. They shouldn't be putting cig-outlets on anything that requires more than 10a IMO. No only can't the wiring take it, but neither can the socket. Do not just add larger gauge wire and bigger fuse to a standard cig-female socket, you'll need to find a cig socket specifically rated for more than 10A.
    Plus, those sockets are so crap, you probably not going to get a full 10A from it even if you find a compressor rated at 10a
    Use the supplied alligator clips on your battery. If they are not long enough, run some decent wire direct from the battery (or starter) along your frame rail to some frame mounted jump posts.
  6. Oct 14, 2017 at 6:24 PM
    2016Tacoman
    J
    Good point.
    Herniator likes this.
  7. Oct 15, 2017 at 4:25 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    There are probably other considerations besides the wire.
