Whats wrong with my shock?!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Sep 22, 2012.
  1. Sep 22, 2012 at 4:08 PM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    So, i was washing my truck today, and noticed that my passenger side shock did not look right. Now i do not have any idea about suspension componets, but i do however have enough common sense to compare it to the driver side, which in turn seemed to look correct. my dad said he thought it needed to just be tightened down, but thats just a guess cause he doesnt know anything about them as well. The pictures would not upload unfortunately but all i can tell you is that the passenger side is showing a metal rod, while the driver side has a boot covering the rod. the passengers sides boot is slid down. also the small rubber grommet and nut and washer on the passenger side is loose and up about an inch out of the larger grommet, while the drivers side is pulled down tight inside the larger grommet.
    Thanks
  2. Sep 22, 2012 at 4:18 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    You can take them off pretty easy to get a better look at them and possibly fix the problem. It's just 2 bolts to get it off
  3. Sep 22, 2012 at 4:23 PM
    tacoman00
    Rockville, MD
    the problem is that i know nothing about them.. just wondering if someone can tell me Anything.. or if its safe to even drive?
  4. Sep 22, 2012 at 4:25 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    keep trying to post pics
  5. Sep 22, 2012 at 4:25 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    So what I'm getting is your boot is loose?
  6. Sep 22, 2012 at 4:51 PM
    tacoman00
    Rockville, MD
    ImageUploadedByTapatalk1348357853.266708.jpg passenger side (problem side)
  7. Sep 22, 2012 at 4:51 PM
    tacoman00
    Rockville, MD
    ImageUploadedByTapatalk1348357901.574908.jpg driver side
  8. Sep 22, 2012 at 4:54 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    what does the the bottom side look like?
  9. Sep 22, 2012 at 4:54 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I wouldnt drive on it, it needs to be adressed now.
  10. Sep 22, 2012 at 4:54 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Looks like you need to put the truck on stands and tighten that nut down all the way so it doesn't slide around
  11. Sep 22, 2012 at 5:15 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    no his shock is riding against his coil, it should riding in the center
  12. Sep 22, 2012 at 5:16 PM
    skeeet
    skeeet Well-Known Member
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    Yeah I looked at the pic again and also noticed the top. thats no bueno!
  13. Sep 22, 2012 at 5:21 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Ya that's not good I thought we were talking rear shocks. I would be careful taking it apart because your springs still compressed
  14. Sep 22, 2012 at 5:21 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Do both shocks have same amount of shaft length exposed at end? Past the nut. I was looking at pics butim on phone and they appear to be the same. If so,is replace both fronts. I never replace one shock.
  15. Sep 22, 2012 at 5:23 PM
    tacoman00
    Rockville, MD
    The shaft in the middle is loose enough that i can grab the bolt up top and pull it back to center it up but it wont stay
  16. Sep 22, 2012 at 5:25 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Looks like the nut is loose on the passenger side shock.:eek:
  17. Sep 22, 2012 at 5:26 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Replace the fronts.
  18. Sep 22, 2012 at 5:27 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    how does the bottom shock mount look?
  19. Sep 22, 2012 at 5:28 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i think your shock was installed wrong. who put it in? take it to them
  20. Sep 22, 2012 at 5:36 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Pull it to the middle and tighten it and see if it stays and I would buy new shocks anyway if this happened
