Whats wrong with my shock?!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Sep 22, 2012.
  1. Sep 23, 2012 at 9:06 AM
    #41
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    nvm, I see the boot thats missing now, looks like some kind of washer or plate is missing from the bottom side of the top of the shock theres nothing to hold the shock to the coil bucket from the underside. look @ the under side of the good shock then compare to the other side.
  2. Sep 23, 2012 at 9:07 AM
    #42
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    i wanna say the rod is broke or unthreaded at the base of the shock
  3. Sep 23, 2012 at 9:09 AM
    #43
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    tacoman00, this is the issue. I still have my old shocks and went to look at them.
    You are missing the shock boot on the problem side. The good side shows the shock boot installed, the problem side shows no shock boot (from your posts #6 & #7). Seems trivial but the shock boot actually has about a 3/8" to 1/2" metal spacer in it that's needed.
    Tightening the nut down as things are now will do nothing. You need the strut removed and a shock boot or equivalent spacer placed just below the inside of the strut sub assembly.
    Hope that makes sense.
  4. Sep 23, 2012 at 9:15 AM
    #44
    tostidos
    Apple Valley, CA
    07 LT 6spd
    +1 theres your answer
  5. Sep 23, 2012 at 9:16 AM
    #45
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Well technically the boot is on his top one (see first pic). It's slid down on the shaft. How that happened, who knows, but that may be the problem. That metal sleeve/nut in the boot is what's supposed to hold the shaft from popping up through the hat.
  6. Sep 23, 2012 at 9:18 AM
    #46
    jivewalker
    Jack MeHoff
    Chucktown
    If that spacer rusted away the boot would slide down on the shaft, makes sense. +1
  7. Sep 23, 2012 at 9:26 AM
    #47
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    If that's the case then there should be a spacer hanging there roughly the same size as the one above the rubber piece. I don't see it in the first picture he posted
  8. Sep 23, 2012 at 9:27 AM
    #48
    photonashville
    Good catch guys, the boot is there but not in the correct location so a gap has resulted.
    At this point, the strut must be removed and a new boot (or equivalent spacer) installed.
  9. Sep 23, 2012 at 9:45 AM
    #49
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    Ok thanks guys! Would it possibly be safe to drive about 6 or 7 miles to my local shop to be fixed? My dad said he noticed the metal shaft in the middle showing 2 or 3 weeks ago so apparently its been like this a while..
  10. Sep 23, 2012 at 9:51 AM
    #50
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    You are going to need to take it all out, replace the top plate. The top plate probably has a slot worn into it from the whole shock moving up and down instead of the the shock moving in and out like it is suppose to.
    The problem is the bottom washer is gone or broke off that goes on top of the boot before the rubber grommet that is in the bottom of the top plate.
    This isn't the metal ring that is normally attached to the boot, that probably broke off after it started to move.
  11. Sep 23, 2012 at 10:27 AM
    #51
    tacoman00
    Rockville, MD
    Is it driveable enough to get it to the shop?
  12. Sep 23, 2012 at 10:46 AM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How far away is the shop?
  13. Sep 23, 2012 at 10:54 AM
    #53
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
  14. Sep 23, 2012 at 11:09 AM
    #54
    4banger09
    Alex
    Nb, Canada
    Leveled
    I think it should be, who knows how long you drove with it like that, just go slow and avoid big bumps.
  15. Sep 23, 2012 at 11:10 AM
    #55
    tacoman00
    Rockville, MD
    Shop is 7-10 miles..
  16. Sep 23, 2012 at 11:11 AM
    #56
    tacoman00
    Rockville, MD
    Also, i may just be ordering new front billies and replace the whole shock instead, if so, will i need the bushing kit that wheelers offers for 20 bucks?
  17. Sep 23, 2012 at 8:28 PM
    #57
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Looks like you will need a new top hat. Not sure what the exact term is for it. Also, you should get new bushings as well just in case the one you can't see is damaged. Maybe just do that for both sides. You may not need new strut assemblies, but, it's your money. Driving 7-10 miles is not a good idea, you never know when something will hit the wrong bump, or some A hole pulls out in front of you and you have to brake hard, I would definitely recommend towing your truck to where ever you are going to have the repairs done. Good luck
  18. Sep 24, 2012 at 4:17 PM
    #58
    tacoman00
    Rockville, MD
    I purchased 2 front bilstein 5100s and the $20 bushing kit... Does anyone know how long it usually takes from wheelers? Im in va..
  19. Sep 24, 2012 at 6:36 PM
    #59
    4banger09
    Alex
    Nb, Canada
    Leveled
    They should offer a tracking number, I have heard they are quick though.
  20. Sep 24, 2012 at 6:49 PM
    #60
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You will likely need a replacement top hat. Wheelers sells it. Or you can buy aftermarket ones (MONROE Part # 907921 is only $18 at Rock Auto).
