Whats wrong with my shock?!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Sep 22, 2012.
  1. Sep 24, 2012 at 8:33 PM
    #61
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    ^^^^^ THIS, this is what you need.
  2. Sep 24, 2012 at 9:31 PM
    #62
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    you can find a lot of parts at rockauto.com. Replacing your front shocks is the best bet. Like mentioned above, it looks like your missing your bottom washer to hold the shaft, or it could have broken off. You'll need to take apart your coilover. the way to hold the shaft to get the nut off is with a closed wrench, and some big vise grips to hold the top of the shaft where it's flat on the sides.
  3. Sep 25, 2012 at 7:18 AM
    #63
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    so i definately have to have a replacement top hat? should i order 2 new ones and do both the front top hats while i got it apart because ive already ordered brand new bilsteins and the $20 bushing set...
  4. Sep 25, 2012 at 7:27 AM
    #64
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The new billies should come with everything you need except the top hat. Not sure what bushings you ordered unless they are the ones for the top hat, which you shouldn't need with new ones. But yes, get 2 new top hats as well.
    From the pic, either the shock was assembled wrong or the rod pushed through the top hat. Might as well make it all new if you are busting it apart, the other one might go soon as well.
  5. Sep 25, 2012 at 9:33 AM
    #65
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Given the low cost of the top hats, you should replace both. The Taco's control-arm suspension isn't as hard on top hats as Macpherson strut suspension designs (where the top hat takes cornering and steering loads), but should still be replaced if worn.
  6. Feb 5, 2013 at 6:37 AM
    #66
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
  7. Feb 6, 2013 at 3:25 PM
    #67
    tacoman00
    Rockville, MD
    Mine turned out being that too bushing that the top bolt sits on had almost completely deteriorated as the bolts could almost pull through. The solution was
    new front shocks for me.
  8. Feb 6, 2013 at 4:16 PM
    #68
    bassinman
    bassinman Well-Known Member
    Gilbert Arizona
    11 Prerunner SR5
    Tint, WeatherTech mats, Differential Breather Mod, Fogs on anytime mod, Seatbelt chime disabled, glove box led's, Rear spring TSB
    You should not be driving the vehicle with the shock loose like that. What has happened is---the boot has failed and the boot (when new) has a metal washer installed in the top of it that acts as a spacer. That washer has either failed or/damaged the shock strut which when new has a ring built into it which holds the boot in the proper position. You will NEVER be able to tighten the upper nut on the shaft. REPLACE==REPLACE!!!!!
