Whats wrong with my tailgate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 762x51taco, Dec 13, 2010.
  1. Dec 13, 2010 at 8:03 PM
    762x51taco
    762x51taco [OP] Well-Known Member
    So my tailgate has a hard time closing, and I can see where its hitting. I am just wondering what is causing this. Bent tailgate? Are the 09s even covered under the bent tailgate TSB?
    I do carry a 500lb quad in the back from time to time and the back is on the tailgate due to the DC reg bed size, but that shouldn't hurt anything. Its not too big of a deal its just kind of irritating. Any help would be appreciated. Thanks.
    It is hitting like this on both sides, no contact in the middle
  2. Dec 13, 2010 at 8:07 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Just looks like it needs adjustment. I dont have my truck here w/ me, but check out the mounting tabs on the sides. Loosen it, see if you can pull it further away from the bed when its in the lowered position. If not, yea, might have been bent a little from loading/unloading?
  3. Dec 13, 2010 at 8:10 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    No, they are not
  4. Dec 13, 2010 at 8:13 PM
    762x51taco
    Pull the bed liner that is on the tailgate farther toward the top of the tailgate? I do ride the quad up there so at times there can be 680 or so on there, but I would like to think the tailgate could handle that.
  5. Dec 13, 2010 at 8:16 PM
    KPT
    09 Prerunner
    I thought the tailgate was rated for 200 pounds, no?
  6. Dec 13, 2010 at 8:37 PM
    762x51taco
    Ya it looks like that it is. And now that I think about it the quad really wouldn't taco in the middle as the weight of it is mostly on the outer sides of the tailgate by the cables. Oh well I guess ill just have to live with it.
  7. Dec 13, 2010 at 8:40 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    My '08 did that after helping a friend move... Granted, he's like 265 plus the TV he was putting in the back.
  8. Dec 13, 2010 at 8:44 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    If you can't adjust the gate , I bet you could get yourself some clearance with a piece of 36 grit sandpaper ( belt sander belt works best ) and some elbow grease .
  9. Dec 13, 2010 at 8:47 PM
    OZ-T
    Peter North
    British Columbia
  10. Dec 13, 2010 at 9:12 PM
    762x51taco
    Thanks, I will have to try that. I would like to know what exactly Toyota did to the 09, 10 tailgates and the TSB tailgates to make them different from the older weak tailgates.
  11. Dec 13, 2010 at 9:24 PM
    OZ-T
    Peter North
    British Columbia
    They are supposed to be reinforced , but are still only rated for about 200 lbs .
  12. Dec 13, 2010 at 9:44 PM
    chatapuggy1
    chatapuggy1 Well-Known Member
    So Cal
    2009 Double Cab TRD Off-Road
    I have an 09' and never had a load in the back as of yet, I am about 215lbs and when I climb on the tailgate to wash the truck it seems real flimsy so I stand on the corner where it seems meatier.
    I notice a TSB through the 07's and it has part numbers on it. Do you think I could just go down to the dealer and order those part numbers and put the pieces in myself rather wait for this thing to bend on its own?
  13. Dec 14, 2010 at 1:07 AM
    JKD
    JKD Well-Known Member
    Has that truck been hit from the back before?
