What's wrong with my tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by StewJ, Jan 22, 2022.
  1. Jan 22, 2022 at 12:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    When parked for hours the part of the tire in contact with the ground gets a flat spot on it. It is worse in cold weather, rarely happens in hot weather. But it doesn't have to be real cold. I've seen it happen in the 50's. Some tires are worse than others. Things will work out after being driven a few miles.
  2. Jan 22, 2022 at 12:43 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    But today isn't either of those days...
    Slick Taco[QUOTED] likes this.
  3. Jan 22, 2022 at 1:18 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    That's not cold, -18 yesterday morning in U.P.
    RedWings44 likes this.
  4. Jan 22, 2022 at 1:33 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    It can happen randomly if it sits for a while. Check your psi too.
  5. Jan 22, 2022 at 1:42 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    58 degree weather causing tires to flat spot? No fucking way! That is damn near summer time weather for some parts.
  6. Jan 22, 2022 at 2:14 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Weeks and months, maybe. Not normal use.
    Bushed likes this.
  7. Jan 22, 2022 at 2:15 PM
    RedWings44
    Michigan
    We have good temps in the LP, just need more snow.
  8. Jan 22, 2022 at 2:24 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Did this happen right after tire install? E load? Pressure? What rate springs on the lift?
  9. Jan 22, 2022 at 5:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    I went through two stock needle bearings (what a goose chase - take my word for it) under warranty before I did the clamshell and I only had a 1.5” coilover lift. Vibes went away immediately and it has taken a beating. Good luck! :hattip:
  10. Jan 22, 2022 at 5:23 PM
    StewJ
    StewJ [OP] Active Member
    2018 Blue Pearl Tacoma TRD OffRoad
    -Aftermarket step rail -Like-stock roof rack -Gator tri-fold tonneau bed cover -1.5 inch wheel adapters -Aggressive aftermarket fender flares -Katana low beam LED headlights -Techmax high beam and fog LED headlights -Matte black plasti-dipped stock wheels -Replaced stock interior lights with LEDs
    If you're born and raised in Florida, 58 is freezing! I've seen snow 3 times in my life. Never in Florida though. 58 degree swamplands is bad enough. It gets near freezing sometimes, but super rarely. 32 is freezing right?
    Mark77 likes this.
  11. Jan 22, 2022 at 5:26 PM
    StewJ
    E load for sure. Tire pressure is usually 30, but today it dropped to 27. Otherwise I keep it around 30. It popped up to 29 when I was driving to work.
    Oh, and my front spring-rate is 590. I don't know the leaf spring rate though.
  12. Jan 22, 2022 at 6:05 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Clearly I'm delusional
    :anonymous:
    Tacowin1013[QUOTED] likes this.
  13. Jan 22, 2022 at 6:13 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    E load and AT tires in general usually have some pretty tall knobs and they can sometimes be felt when rolling slow. Higher rate springs and things like urethane bushes and hiem joint control arms transfer more of those small vibrations through the chassis. 590 springs and 30 PSI is pretty soft, though. In fact 30 PSI for an E-load tire is below the minimum load rated pressure. Most E load tires will carry around 1900 lbs at 35psi (assuming 4 tires carrying equal load), which would translate to a 7600lb truck, but going below the rated pressure/load carrying is not necessarily a linear correlation so below the mfg minimum load carrying pressure is a bit of an unknown.
  14. Jan 23, 2022 at 6:04 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    I have only experienced tires flat spot 2x, once on a car that sat for 4 yrs with no movement. I bought it real cheep, put 2200 in it to get it drive able. The first time rhe car was outside a hotel and the temperature dropped to -50 ambient temp. No wind chill, after a couple blocks no issues.
  15. Jan 23, 2022 at 11:46 AM
    #35
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Tires will flat spot if they sit in one place on the truck too long. Shouldn't happen with decent air pressure for at least 2-3 weeks.
  16. Jan 23, 2022 at 11:52 AM
    #36
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Duratracs for the win!
  17. Jan 23, 2022 at 1:24 PM
    #37
    StewJ
    Is 27 psi low for an E-rated tire on a mostly stock weight Tacoma?
  18. Jan 23, 2022 at 2:23 PM
    #38
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    That's why you guys have baby booms Sept - Nov :D
