What's wrong with my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beccab80, Aug 24, 2021.
  1. Aug 24, 2021 at 2:20 PM
    Beccab80
    Beccab80 [OP] Love my Toyota
    Becca
    Cameron, Ok
    2008 Toyota Tacoma base runner
    Idk my battery light came on yesterday my trucks died 3 times going down the highway and restarted itself my radio changes stations on its own and my blinkers when I use them my bright lights come on so yesterday it died going down the road and I had to get jumped well my battery cable was corroded I cleaned it it started right up the light went off and I was able to drive it home I had alternator checked it's good it's got a new battery and now my check engine light is on and it will start and drive but it sounds like it's going to die when I come to a stop or it's in park can anyone shed some light on this for me cause idk whats going on with it and I don't trust alot of people to even be under the hood
    FishnTx likes this.
  2. Aug 24, 2021 at 2:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It would help us to know why the check engine light is on.
    Most auto parts stores will check it for free. (Advanced-Aoti, AutoZone, O’riley’s)
    They can scan the truck for trouble codes.
    These trouble codes are what make the Check Engine Light come on.
    Once we know what the codes are, we can probably help point you in the right direction.
  3. Aug 24, 2021 at 2:48 PM
    N8diggity
    N8diggity Well-Known Member
    DFW, TX
    ‘20 DCSB OR Silver
    “Sounds like it’s going to die I park or come to a stop”
    Does it sound normal when in motion?
    When did you last replace the spark plugs?
  4. Aug 24, 2021 at 10:31 PM
    Beccab80
    Becca
    Cameron, Ok
    I don't know I bought it from my step dad I'll ask him tho and runs fun going down the road just when I go to stop it acts like it wants to die and shakes bad
  5. Aug 25, 2021 at 2:50 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Wow, welcome to TW!
    Beccab80[QUOTED][OP] likes this.
  6. Aug 25, 2021 at 3:14 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Torspd, Beccab80[OP] and blu92in99 like this.
  7. Aug 25, 2021 at 3:29 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean the throttle body
    Beccab80[OP], DocD and 4WDTrout like this.
  8. Aug 25, 2021 at 3:43 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    All things point to an electrical issue. Maybe a short somewhere.
    Torspd and Beccab80[OP] like this.
  9. Aug 25, 2021 at 7:07 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    When the battery is disconnected the engine computer is reset. It is relearning proper throttle opening to idle. Drive a few cycles and it should smooth out. The light may go out on it's own.
    The weird issues were probably caused by the corroded battery cable, which you have already fixed.
    6 gearT444E and Beccab80[OP] like this.
  10. Aug 25, 2021 at 4:25 PM
    wayne0
    wayne0 Well-Known Member
    Some punctuation would help immensely in reading that wall of words as well.
  11. Aug 25, 2021 at 5:00 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I’m no mechanic but, I’ve had my fair share of time learning how to fix my 08 Tacoma either with a friend, my bro, or on my own. If I were to take a guess, I might go with what either of these two guys said.
    Having said that, get a diagnosis tool hooked up to your truck to see what codes it’s throwing if any. Once you see the codes, then you can start trouble shooting to determine the source of the problem. I hope you get everything resolved.
  12. Aug 25, 2021 at 5:06 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    ^^^Do the above. Since your check engine light is on when you find out what codes are on you’ll know a lot more about what could be wrong.
    Anything else is just guessing.
    Beccab80[OP] likes this.
  13. Aug 25, 2021 at 5:19 PM
    Larzzzz
    Larry
    MA
    Ya
  14. Aug 25, 2021 at 5:28 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    ah the infamous check engine light lol. As they say above go to Autozone and let them scan your truck and see what's going on in there.
  15. Aug 26, 2021 at 10:29 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Also, make sure your gas cap is on tightly ;)
  16. Aug 26, 2021 at 6:38 PM
    Beccab80
    Becca
    Cameron, Ok
    Where is the gas cap located exactly? Lmao just kidding!! And there's you some punctuation I was in a hurry when I wrote this I was at work my apologies. Thank you guys after it got reset it started driving normal after a couple times. But this evening check engine light came on again and so I'm taking it to AutoZone. This truck is my baby. Ive learned how to change the oil myself I replaced the fan motor myself last summer. My dad had it first tho and he was rough in it. Pisses me off but it's a darn good truck. It's got 277,767 miles on it. So I baby it when I can. Thank you guys again
    Torspd, Blockhead, N8diggity and 3 others like this.
  17. Aug 26, 2021 at 8:01 PM
    davidstacoma
    David
    NC
    Good luck. When you get the codes post them here someone might be able to help you know where to start troubleshooting.
    4WDTrout likes this.
  18. Aug 28, 2021 at 4:27 AM
    Blockhead
    Pittsburgh, Pa.
    Really cool that you’re doing some of your own wrenching :thumbsup: YouTube and the good folks in this forum will take you a long way in saving money and getting to know your truck. Use the search in upper right on the page and usually you’ll find what you’re looking for. If not, ask away and you’ll get answers. So many knowledgeable people on here ... Good luck!
  19. Aug 28, 2021 at 5:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you live on/near a farm ,or heavily wooded area? Not necessary, but most typical for a lot or rodent related wiring issues.
    Did your dad add any modifications which were electrical in nature? Radio, etc?
    I had a buddy some years ago, that became so enraged with his truck from strange electrical issues, that he de-modded it and sold it. Every time he would use one turn signal, it would blow the MAF sensor and a fuse.
    Upon pulling the aftermarket radio and another component, I found many poorly spliced connections. They were shorting out. "Spliced" is an overstatement.
    Definitely check the engine wiring harness and connections. If there were mods in the truck, check the wiring there too.
    CurtB and winkel like this.
  20. Aug 28, 2021 at 5:49 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
