What's your ave coolant temp?
Discussion in '1st Gen. Tacomas (1995-2004)' started by life as ben, Jun 17, 2020.
  1. Jun 19, 2020 at 4:30 PM
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
    JIGGLE DOWN DOG!!!! 188 all day!
    cruiserguy likes this.
  2. Jun 19, 2020 at 6:47 PM
    tacoma4
    tacoma4 Well-Known Member
    I wonder what the acceptable accuracy is of this sensor. Probably has a +/- 10% tolerance from the factory.
  3. Jun 19, 2020 at 6:52 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Last Summer, I plugged in the scanner for a reading while I drove around town (100+ and very humid), my numbers ranged from 185-190 F.
    I will check again soon and report.
  4. Jun 19, 2020 at 7:22 PM
    life as ben
    life as ben [OP] Well-Known Member
    Well damn. I installed the jiggle wiggle wrong. I'll change it tomorrow and let you'll know what happens.
    JJ04TACO and cruiserguy like this.
  5. Jun 20, 2020 at 1:35 PM
    eon_blue
    Azusa, CA
    Should do the trick. If you're at 198° now that should lower it to 188° on average which is what it's supposed to run at
  6. Jun 20, 2020 at 6:49 PM
    life as ben
    Jiggle jiggle wiggle wiggle and my temps are back to norm!
    Thus concludes the experiment.
    thanks for all the help!
    j4roe, jbrandt, cruiserguy and 2 others like this.
  7. Jun 20, 2020 at 6:50 PM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    Glad you got it sorted, thanks for reporting back :thumbsup:
  8. Jun 20, 2020 at 7:15 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    After I did my timing belt and water pump, I installed my Toyota thermostat with the jiggle valve at 12:00 (out of habit). My coolant temps on my Ultragauge would go as high as 210 going uphill. I took out the thermostat to put the valve at 6:00 and now the highest the coolant temp gets is 196.
  9. Jun 22, 2020 at 1:20 PM
    MamaTried81
    MamaTried81 Well-Known Member
    Oakland, CA
    '02 TRD Tacoma 4x4 V6 XtraCab SR5
    Yep, as others have said, on the 3.4L the jiggle goes down (6 o clock). I just confirmed this myself today.
    I have a 2002 Ext Cab 3.4L TRD 4x4 running Toyota red coolant, and I recently bought an UltraGauge. I saw my operating temp was always steady at 199-202F once warmed up. Today I drained the coolant and took the thermostat housing off, BINGO, the jiggle was up at 12 o clock. I rotated it 180 degrees, put it all back together, and now I'm running at 188-190F.
    It may not make any sense, but it is 100% confirmed by many folks here at TW.
    j4roe, life as ben[OP] and cruiserguy like this.
  10. Jun 22, 2020 at 1:31 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    69F
    j4roe and cruiserguy like this.
  11. Jun 24, 2020 at 10:40 AM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    A lot of bad information on the web about putting it in the 12 o clock position from people who say they got that information out of the FSM. I have a PDF version FSM for year 2000 I believe and it definitely says 6 o clock. I actually did a test and put it at 12 o clock and the difference is 20 degrees!!!! JIGGLE DOWN DOG FOR THAT 188 GAME.
    Jimmyrace and cruiserguy like this.
  12. Jun 24, 2020 at 12:04 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    2.7 I4 jiggle goes at 12 o'clock ... with it at 12 in my 4 cyl I get 183 to 189 depending on how much stop and go traffic I'm in
  13. Sep 1, 2023 at 8:42 PM
    redneck_adjacent
    redneck_adjacent Well-Known Member
    Bellevue, WA
    1997 Tacoma 2.7L 4x4 W59 MT
    5 PSI supercharger 3" lift Bilstein 5100 shocks Old Man Emu springs General Spring leaf springs with 2" blocks and extended shackles 31" Firestone Destination XT tires LCE header and catback exhaust HPS CAI Tundra S13WE front brakes KC HiLites flood, ditch, fog, and backup lights Eaton Bussmann relay/fuse panel with custom power tray All Pro bumpers, sliders, and skid plates
    Normally, my thermostat reads 187-188. It rarely - and I mean rarely - deviates.
    Today, I drove *hard* down I-5 in Northern California. The thermostat rose to 192. It has never gotten so hot before.
  14. Sep 2, 2023 at 9:46 AM
    MPM13
    MPM13 New Member
    2001 2RZ-FE
    Hey Toyota - Put a jiggle valve on top and bottom....
    lajeff likes this.
  15. Dec 31, 2024 at 1:47 PM
    #35
    lajeff
    lajeff Member
    Bfe Fla
    97 Tacoma extra cab 4wd v6 m/t 382k, 265/75/16
    Another person posted FSM normal operating temps are 176 - 203 F.
    My jiggle valve is at 12, and it runs 178 to 181.
  16. Dec 31, 2024 at 2:12 PM
    #36
    phoforbreakfast
    phoforbreakfast Well-Known Member
    My temp reads 176 F/80 C with the Corolla 170 F thermostat. Is it normal for the AC not to blow hot air when the engine reaches operating temp and idling on max heater?
  17. Dec 31, 2024 at 2:33 PM
    #37
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Huh?
  18. Dec 31, 2024 at 2:50 PM
    #38
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like your cold(er) thermostat is affecting your heater performance
    I don't know why guys get so obsessed over +/- 10 degrees. A cold thermostat won't protect anything, it'll just make you run around luke-warm and get crappy gas mileage. Picture the catalytic converters getting soaked with raw fuel..
  19. Dec 31, 2024 at 5:38 PM
    #39
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    That's a bit much... Running 20* colder is just fine as long as it's consistent. I wouldn't run one here in AZ though because my temps run up to 220, but it's not going to affect your gas mileage as it's not going to run richer
  20. Dec 31, 2024 at 6:06 PM
    #40
    phoforbreakfast
    Yeah, I'm in the desert too and running a supercharger now. I figured it wouldn't be a bad idea running the 170 F thermostat with that in mind. @lajeff, you're probably right about the heater core. Had some AC issues not too long ago but never replaced the heater core so that might be on it's way out or clogged. If I drive the truck around, the air does get hot on heater but not super hot as before when I had the 180 F thermostat.
    lajeff likes this.
