What's your experience with AAL?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ben20004x4, Jun 26, 2023.
  1. Jun 26, 2023 at 10:16 PM
    ben20004x4
    ben20004x4 [OP] Well-Known Member
    TAMU
    2000 SR5 130k miles
    Howdy,
    I've pretty much settled on buying the Toytec Bilstein 5100 kit for my truck(includes coilovers, struts for back, and 2 AALs), along with some JBA UCAs. However, I'm a bit concerned about some people saying that their leaf pack has split and/or cracked because of an Add a leaf. My truck has 107k miles, and I do wheel sometimes but maybe 4-5 times a year at most, and almost never haul any sizeable loads. Are tired old leaf springs the prime canidates to break with AAL, or is it only something to be worried about if you are giving them constant stress? My solution would be just getting a Dakar leaf pack or something similar.
  2. Jun 26, 2023 at 10:23 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    AAL does the trick unless you are carrying a lot of weight or driving like a maniac on rough surfaces.
    Edit: AAL is good with good working condition leaf pack not the ones already on a “n” shape.
  3. Jun 27, 2023 at 7:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If your springs are worn out it might be time to replace them.
    Adding extra capacity to tired springs can cause problems as it can change how the springs flex.
    Xbeaus and Ricardo13x like this.
  4. Jun 27, 2023 at 9:55 AM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    In my experience, when you add an AAL to a tired leaf pack, it won't last long. 1-2 years max depending on use.
    Ricardo13x likes this.
  5. Jun 27, 2023 at 9:58 AM
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    Maybe I'm a bit ignorant here, but after strongly considering AAL for awhile, the effort and return you're getting out of it just doesn't make sense to me. Unless buying a new leaf kit is just absolutely out of the question, it seems the best and easiest way is an entire new leaf pack.
    Bivouac likes this.
  6. Jun 27, 2023 at 4:02 PM
    ben20004x4
    TAMU
    2000 SR5 130k miles
    Sounds like a new leaf pack is best then. I've also heard AAL is very stiff.
    What is everyone's favorite leaf pack? Maybe I'm looking in the wrong place but I don't see any on the OME website, everything seems to be for 2005+.
  7. Jun 27, 2023 at 4:06 PM
    Bishop84
    Bishop84 Well-Known Member
    AAL's are much better now. But on the 1st gens they used to ride quite rough because of how light the rear end was.
    The other problem was helper springs like helwigs. They rode AWFUL on the 1st gens.
    I'd agree with the others. Get a pack and do it right.
    A simple factory spring replacement with a 1" block is all you need, but you can get an upgraded pack if you want a little bit of lift.
  8. Jun 27, 2023 at 4:43 PM
    boshak
    AG
    CA
    I was really happy with my OME Dakar leaf pack. Look at Wheelers Offroad. They should have them.
    Other popular packs are All Pro, Alcan, Deaver. All depends on what type of use you want to put them through.
  9. Jun 27, 2023 at 6:38 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I put a cheap aal on my 290k mile springs and everything’s still fine now at 356k miles. Wheeled regularly and has towed its fair share of trailers
    tnzs and phoenix ray like this.
  10. Jun 28, 2023 at 9:23 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Had AAL for a long time on my 98. Hauled a dirtbike on the back and snapped one right off. They are good for helping tired old springs and that's about it.
    phoenix ray likes this.
  11. Jun 28, 2023 at 8:03 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    The first lift I did on the rear of my 02 was with a Toytec AAL. It wasn't bad but I eventually went to a pair of Dakars. The Dakars were a noticeable improvement in terms of travel and articulation, but surprisingly didn't handle a load as well as my stock packs w/AAL. I was running a fiberglass shell back then, and loaded with just my work tools it would sag a little more than I wanted. I then added one of the OME extra leaves to the packs and all was good. I've considered removing the extra leaf since I no longer run a shell, and rarely have much of a load, it rides fine though just has some extra rake.
  12. Jun 29, 2023 at 8:37 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    If you have the money available, Deaver J59s without question. If you don't have $1500 to throw at that, or it seems steep (it is), a 3 leaf AAL is a GREAT alternative. You remove the overload and swap in the 3 leaf AAL and it's almost like the more expensive options.
    Keep in mind that with either solution, that you'll need new u-bolts as they are single-use items. Also watch the rear brake line as you do the work- you need a new one too if you're lifting the back.
  13. Jun 30, 2023 at 8:35 AM
    ben20004x4
    TAMU
    2000 SR5 130k miles
    That’s good to hear- the Toytec lift I was looking at has that 3 AAL as an option for only like $170 more. I’m guessing it’s a bit more supporting on the stock leafs than the single AAL. Probably gonna go for that, the Deavers are a bit pricey and I just don’t do a huge amount of off road to warrant $1500 leaf springs, but OME at $400 seems very justified. Wheelers offroad indeed have them.
    Thanks everyone for the responses, very helpful.
    AusBerg likes this.
