What's your favorite OBDII Scanner setup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by r1scooter, Jul 24, 2017.
  1. Jul 25, 2017 at 9:21 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    I don't plan on leaving mine plugged in as this is my second ODB2 bluetooth device. The first one died... maybe from being plugged in all the time? Anyways, I just want data for some drives, don't need it all the time
  2. Oct 28, 2017 at 9:06 AM
    Adrawk
    Adrawk Active Member
    Adam
    Riverside, CA
    2014 Tacoma Prerunner SR
    do tires count?
    This works great when you don’t live in CA! I had car problems in AZ and loved doing this, helped me buy the part I needed to fix right there at autzone, but CA wouldn’t do it.
    LivinLoud[QUOTED] likes this.
  3. Feb 16, 2018 at 4:00 PM
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    Same here !!! Just found out that in the state of Hawaii auto part shops are prohibited from lending them out.
    Sucks... I’m an Apple user. Any recommendations
  4. Dec 6, 2018 at 5:20 PM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Does anyone has a setup that works on Android 9.0? I've tried 2 devices (Bluetooth/wifi) from Amazon and neither has worked. Both failed to connect and both went back. There's an issue with 9.0 specifically. In fact when you open Torque it notifies you there is a conflict with Pandora.
  5. Dec 6, 2018 at 10:52 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    If you ever need to use Tech stream just let me know I have a windows laptop and cable. Not sure where on the island you are but I'm in Kapolei.
  6. Dec 7, 2018 at 4:13 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Kiwi 3 adapter and fusion app pro on I phone 8+.
    r1200gs4ok likes this.
  7. Dec 7, 2018 at 2:14 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Second the kiwi 3
  8. Dec 9, 2018 at 5:31 AM
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I have original Kiwi with iPhone, works fine.
  9. Dec 9, 2018 at 5:57 AM
    WillT11
    WillT11 Well-Known Member
    Will
    Very casual use here, but happy with the OBD Fusion and the Veepeak OBD2 bluetooth scanner. But I'm more of a casual driveway mechanic...when someone lets me use their driveway ha
  10. Apr 12, 2019 at 10:24 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    this is the set up i was hoping to see because i like the kiwi 3 and was hoping it could be used with the fusion app......now that i know that application is possible and works I ma going to get both....thanks for posting
  11. Apr 13, 2019 at 4:20 AM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Kiwi would be even better if Apple CarPlay could work
  12. Apr 13, 2019 at 4:50 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Does anybody's scanner read the tpms?
  13. Apr 13, 2019 at 6:56 AM
    ARB1977
    North Texas
    I had an Android with the kiwi 3 torque pro app. The fusion app works on iOS.
  14. Apr 13, 2019 at 9:06 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    thank you....
    ARB1977[QUOTED] likes this.
  15. Apr 20, 2019 at 11:58 PM
    #35
    Reign808
    Reign808 Well-Known Member
    Ian
    2013 Tacoma 4dr
    Magnasun charger, walbro 255, TBS, K&N intake, LED everything, cosmetic mods
    Howzit bra, can you message me what you're using for techstream?I need to get one to flash the trd tune on a new used ecm apparently the dealer here on kaua'i is unable to do so
  16. Apr 21, 2019 at 1:13 AM
    #36
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I just drive mine 'til it forks up; then I hook up my hand-held scanner and fix it.
  17. Apr 21, 2019 at 5:51 AM
    #37
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    I use Bluedriver. It's not cheap. Maybe it's even overpriced. I thought I would put it out there, so other users can tell you why not to spend that much on it(I would like to know :))
  18. Apr 21, 2019 at 11:44 AM
    #38
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    To flash an ECU you need to buy a real MongoosePro cable, which costs about $500. I am using a dL copy of Techstream and a mini vci cable. But also to flash you’re gonna need to be able to get the cal file. If you don’t have it already you would need to find one online or do a month subscription to tis.
  19. Apr 21, 2019 at 12:36 PM
    #39
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Fusion iOS
    AmateurTaco1313 likes this.
  20. May 5, 2021 at 8:02 AM
    #40
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Does this one tell you what gear the truck is in?
