What's your favorite rear differential oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Jul 29, 2021.
  1. Jul 29, 2021 at 5:41 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I like this gear oil as it handles severe shockloads like 3500 rpm transbrake launches
  2. Jul 29, 2021 at 6:59 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Yeah, but does that make it functionally better for a vehicle that doesn’t see 3500rpm transbrake launches?
    US Marine[QUOTED] likes this.
  3. Jul 29, 2021 at 7:31 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes because it's designed for both High Performance and Commercial applications which reduces shock loads
    • High-performance, extreme high-pressure gear lube
    • Multi-purpose applications including manual transmissions and both conventional and posi-traction differentials
    • Contains special "clinging" agents that provide direct adhesion to all moving parts whereas conventional lubes rely on "splashing and sloshing" to distribute lubricant
    • Increased speed of rotating parts causes continuous film of oil to "climb" and spread over surfaces
    • Insures complete lubrication of gears, bearings, bushings, shift yokes, synchros, etc.
  4. Jul 29, 2021 at 7:41 PM
    OpeCity
    Long Beach, CA
    Is that *demonstrably* better for our non-commercial, non-racing vehicles than the claims of other oils? And on what do you base that?
    for instance, over at mobil1:
  5. Jul 29, 2021 at 7:43 PM
    brwntms
    brwntms Well-Known Member
    My go to is Supertech as for the rear differential oil of choice.
    steelcity2 likes this.
  6. Jul 29, 2021 at 7:46 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    I use redline. My truck calls for 75w-85 according to the owners manual. Its either redline or Toyota and I can source redline from the summit racing warehouse 15 minutes from my house
  7. Jul 29, 2021 at 8:35 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    :eek:
    tacoman45 likes this.
  8. Jul 29, 2021 at 9:04 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I found a batch of Amsoil severe gear diff oil for $8.00/qt at my local Coastal so I ran that for my last change. I think next time I’ll run Redline and see how it holds up.
    ECGS has a good write up on which gear oil to run - in short, just change it with something that meets spec and when you’re supposed to. You’ll be fine.
    Do not put 5w-30 in your diffs. Period. Engine oil is not the same as differential gear oil
    wi_taco likes this.
  9. Jul 30, 2021 at 7:36 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I use AMSOIL Severe Gear 75w90 because it costs more it gives me a sense of elitism over other Tacoma owners. Also it tastes good & is less filling which is important to me for a balanced diet (also pairs well with cheeseburgers).
  10. Jul 30, 2021 at 8:15 AM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    If you listen to an Amsoil rep they will tell you you can brush your teeth with the stuff.
    RedTaco68, steelcity2 and tacoman45 like this.
  11. Jul 30, 2021 at 8:31 AM
    wi_taco
    Adam
    SE Wisconsin
    They wouldn't be wrong (technically), however you can also brush your teeth with raw sewage. Neither are probably good ideas. But yeah I brush my teeth with Amsoil.
    RedTaco68 and tacoman45 like this.
  12. Jul 30, 2021 at 4:48 PM
    slayer fan
    slayer fan Well-Known Member
    tommy
    ky
    2013 tacoma 4x4 regular cab
    2" lift.
    amsoil severe gear. because it makes me feel better.
    RedTaco68, tacoman45 and wi_taco like this.
  13. Jul 30, 2021 at 9:10 PM
    Waasheem
    Waasheem
    2007 xrunner
    3 in 1 works for motor, transmission, differential, all 3. So I only need to buy one kind of oil since I’m easily confused. No brainer, dump it in. No thinking if I grabbed the correct bottle.
  14. Jul 30, 2021 at 10:03 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I use Lucas gear oil in my diffs just cause that's what ECGS recommends. As for my trans and transfer case I run Redline
  15. Jul 31, 2021 at 3:48 AM
    #35
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    ^^^ Exactly what I do! Redline 75w-85 from Summit Racing in Arlington TX
    Heyyo_Friday[QUOTED] likes this.
  16. Jul 31, 2021 at 3:54 AM
    #36
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Why not use 4 in 1 so you’re good for the transmission fluid change, too?
  17. Jul 31, 2021 at 8:11 AM
    #37
    Taniwha
    Taniwha Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
  18. Jul 31, 2021 at 8:13 AM
    #38
    Taniwha
    Dave
    Kamloops, B.C.
    Because of the transaxle sharing fluids from diff to tranny, it greatly complicates things
  19. Aug 1, 2021 at 10:39 AM
    #39
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    This is what I'm going to do. Have the MTL for the tyranny and transfer case, picked up Lucas 75w-90 for the diff
  20. Aug 1, 2021 at 6:16 PM
    #40
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Redline is good for the differentials.
