What's your gas mileage with 33" tires or bigger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4X42HEL, Jan 14, 2011.
  1. Jan 14, 2011 at 7:59 AM
    4X42HEL
    4X42HEL [OP] Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    Hi,
    Please don't bash or say stuff like "go get a prius".
    I just want to know what MPG most people are getting with whatever lift they have, whatever gears they have and with 33" tires or larger.
    I'm sure this will be useful to many people wanting to know different setups and what others are getting. Also, I am aware MPG is driver dependent, and dependant on many other things, but just for points of reference. That being said, if you can just fill out these fields:
    Example:
    Gear Ratio: ("Stock", [or modified ratio number])
    Tire brand/type: "Nitto Muds", "BFG ATs"
    Tire Size: 33"
    (Optional) Lift Type/Size: "Spacer, 2 inch "
    MPG: 14
    Something like that,
    Thanks in advance :)
  2. Jan 14, 2011 at 8:19 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    MPG: 23.5-25
    Tires: 255/85/16 = 33.1"
    Cooper ST Discoverer
    Gears: 4.10 gears
    Lift: 4.5" lift up front, 2" rear
    Engine: 4 banger with a few breathing mods
  3. Jan 14, 2011 at 10:21 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Fuckin 4 bangers you guys always get good mpgs
    02 3.4
    3" lift
    33x12.5s
    Stock gears
    18mpg to 20mpgs at 75mph
    Shaw’s4X4 and Alexely999 like this.
  4. Jan 14, 2011 at 10:24 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Gear Ratio: Stock 4.1
    Tire brand/type: Good Year MTR/Kevlar
    Tire Size: 285/70R17
    Lift Type/Size: Ole Man Emu 3"
    MPG: 15.6mpg avg over the last 12 fillups tracked using "Car Care" iPhone App.
    Model Engine/Trans: 4x4 Std Cab 4 cyl 5sp
    Driving: pretty light on the gas pedal daily 18mile commute city traffic stop & go
  5. Jan 14, 2011 at 10:27 AM
    Jm1hawk
    Jm1hawk Well-Known Member
    Jamie
    Irvine
    05 4x4 black
    OME885s MT 17 inch powdercoated rims BHLM 20% tint Alpine headunit Hifonics 1600 W mono amp 2 10" alpine type R subwoofers
    33 muds 3 inch lift getting 14 mpg do mostly city drivimg
  6. Jan 14, 2011 at 10:27 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Gear Ratio: Stock 3.73's
    Tire brand/type: BFG KM2's
    Tire Size: 35"
    (Optional) Lift Type/Size: Icon 3"
    MPG: 15.6
  7. Jan 14, 2011 at 10:31 AM
    sooner02r1
    sooner02r1 Well-Known Member
    08 V6 double cab long bed
    2.5" lift
    16" racelines
    285/75/16 Yokohama Geolandar AT-s
    Stock gears
    17-18mpg average, but stays about the same with all highway at 75-80mph
    Just got back from a trip, had sandbags in the back, plus luggage, got 14mpg on first tank, then threw out the sand, mpgs returned to normal.
  8. Jan 20, 2013 at 8:30 AM
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    Are you guys are compensating with how much further you are actually traveling with larger tires? Or are you just looking miles on your trip odometer and dividing by gallons/ fill up.
    With 285/70/17 vs stock 265/70/16 tires, when my speedo says 60 on the dash, I'm really going 64mph. Keep that in mind...
    60mph for 1 hour on the dash, would be in traveling 64 miles real life, put that through 300 odo reading and you;ve gone 320 actual miles (or aprox 1-1.5 gallons of fuel to miles per gallon that you're not compensating for) marinate that in your brain for a little.
    so, everyone who says their gas milage dropped horrible amounts, sure more weight to turn takes more power, more rolling resistance, but once you're going it doesn't take very much more power to keep you at a steady 60mph vs being stock. i think we're losing some, but not as bad as you may think people are making it out to be.
    i say -0.5 mpg at the max
    2015WhiteOR and boogie3478 like this.
  9. Jan 20, 2013 at 8:52 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Dbl cab 4X4 short bed 2010 OR 6cyl, auto.
    Gears stock
    Tire 255-85-16 BFG KM2
    Lift OME 886 and Icon (for not much longer) 3 leaf AAL
    Plate bumpers, Skids all around, Winch, full size spare, recovery crap, 60" Hi-lift jack,ect.
    Hiway round trip to Prescott Az. from 1000' to 5000' and back to 1000'
    65-75 mph
    16mpg without compensating for odo. difference
    City I am too skeered to check as I fill it up at about 3/4 tank to keep as much weight in it as possible!!
  10. Jan 22, 2013 at 1:27 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    285 70 17 (33") BFG A/T
    3" lift
    18.3-18.5 mpg highway (@70-75 mph)
    14.5-16 mpg city, usually depends on how much i sit in traffic
    stock gears
    Shaw’s4X4 likes this.
  11. Jan 23, 2013 at 3:15 PM
    N8iV Warrior
    N8iV Warrior Well-Known Member
    Johnny
    Indian Reservation Not by Choice
    07 Silver Dble Cab Trd Sport 6" fabtech lift
    6" Fabtech lift, 34" tires , AFE Cold air intake, Cobra wxst75 cb, Rocky Mountain Radar, L.e.d Headlights, L.e.d maplights,dome light, license plate lights, Tinted frnt windows 35% to match rear windows. ARB bumper with XD-9000 Warn Winch, Pro-Tech HeadAche rack with Pro-Tech Toolbox, Icon Front Coilovers for 6" Fabtech lift, Blacked out Taillights PIAA plasma ION 520 Lights, AFE CAI Pro Dry S Filter, 22" Led light bar, Yakima Mega Warrior basket
    averaging about 14-16 if i let off the gas pedal
  12. Feb 17, 2013 at 6:09 PM
    Nicky Lam
    Nick
    just thought i would share this info
    i went 60.8 actual miles today, and the odometer only registered 57.1 might not seem like much... but, when i go 121,600 actual miles it will only register 114,200 on the odometer.
    if it gets there...
    486,400 actual miles will register only 456,800 miles
    help a little with resale value, and all that gas and MPG not accounted for adds up doesnt it
  13. Feb 17, 2013 at 6:13 PM
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Gear Ratio: 4.56
    Tire brand/type: Duratracs
    MPG: 14
  14. Feb 17, 2013 at 6:19 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    2011 DCLB 4X4
    3" Lift
    285/70 R17 tires
    Stock gears
    Scangauge reads about 15-17mpg around town and 17-21mpg on the highway.
  15. Feb 17, 2013 at 6:27 PM
    Nicky Lam
    Nick
    no idea how to convert this this miles per gallon for each tank
    but 243.2 acutal miles, your odometer will say 228.4
    243.2 actual miles / 16gal = 15.2 mpg
    228.4 odometer miles / 16 = 14.2 mpg
    safe to say what ever you are calculating adding +1 to that seems reasonable. the further you go on the tank the higher that number, extra 1.5 - 2.0 mpg is very possible
  16. Feb 17, 2013 at 6:39 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    14.7 mpg average with 4.88's and 37's. I also have a well tuned motor (dialed to stoich below 3000 rpms, 12.5:1 above 3K) and a six speed. I also run premium non ethanol fuel.
  17. Dec 8, 2014 at 7:53 AM
    Kinderliving
    Kinderliving Member
    Lake Tahoe, CA
    99 Tacoma 3.4L MT
    Rancho Quicklift Fabtech AAL
    Gear Ratio: Stock
    Tire brand/type: BFGoodrich All-Terrain T/A KO
    Tire Size: 33"
    Lift Type/Size: Rancho Quicklift w/ Fabtech AAL
    MPG: 20.3 (mixed city/hwy @ 5500-7600ft)
  18. Dec 8, 2014 at 9:17 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Tire-size-conversion.com. you can get actual % difference between 2 different tire sizes. Makes it a lot easier, and accurate to figure mpg's.
  19. Dec 8, 2014 at 11:11 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    I'm averaging 19-21 on 255/85/16s with my 5sp 2.7 4.11 gears
  20. Oct 29, 2018 at 7:42 AM
    cbredman39
    cbredman39 New Member
    Christian
    2002 Tacoma
    4”lift, safari snorkel, Warn winch XDC-S 9.5-S
    2002 Tacoma 4” lift 33” avg. 17-19 city 21-23 highway
