What's Your Gear Oil Level Check Interval?
Discussion in 'Technical Chat' started by OffroadToy, Nov 2, 2013.
  1. Nov 2, 2013 at 3:21 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Once the rear/front differential and transfer case gear oil gets changed out i check the levels once afterwards after driving it and forget about it till the next drain/fill (unless there's a visual leak.) I don't drive much so they get changed out every 5 years (comes out to every 15-20,000 miles.) I've never had an issue but wondered if this was a good practice... how often do you check yours?
  2. Nov 2, 2013 at 3:23 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If it's not leaking I don't check it.
  3. Nov 2, 2013 at 3:34 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
