What's your height with 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stanman9, Jul 9, 2009.
  1. Jul 9, 2009 at 3:48 PM
    stanman9
    stanman9 [OP] Well-Known Member
    Toytec co's and aal, tc uca's
    Those of you with 3" what's your height from the ground to fender at the center of the front tire (if you were to drop a line from the fender to the ground down the center of the hub)???? I just installed toytec co's and cranked them all the way and it looks lower than with the 3" spacer I had before. thanks!
  2. Jul 9, 2009 at 3:51 PM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    from center of wheel up to fender I went from 20.0" to 23.0" 9exactly set up at 3.0" of lift
    I don't know from the ground. But you could measure yours from wheel center to fender and compare. Stock shoudl be very close to 20 inches
  3. Jul 9, 2009 at 4:09 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    +1, measuring from the center of the hub to fender is more accurate. I am at 23.6 but I have 3.5 inches up front.
  4. Jul 9, 2009 at 6:43 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I am at 39"s in the front with 885 coils, top plate spacer and 5100's. 40" in the rear with a 2" AAL and 5100's. Running 18"s on 33"s. This is of course the drivers side with the taco lean. I think its about 3/4" higher on the passenger side.:rolleyes:
