What's your MPG...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MT_mudflaps, Oct 30, 2008.
  1. Oct 30, 2008 at 7:26 AM
    MT_mudflaps
    MT_mudflaps [OP] Just playin' on the runways
    Clint
    Bellflower, CA
    Indigo SR5 PreRunner with TRD off road
    with the rear differential lock on?!!! :rolleyes:
    The wife got back home from the gym this morning and said, "Is there something wrong with the truck? The wheels "sqweek." "
    :eek::eek: Huh? What? What you mean the wheels "sqweek?"
    So I go out get in the truck, start it up and guess what's on???
    Yup, the rear diff. lock.
    I come back inside and ask her how long was the truck like that? when did you notice it? how fast were going?
    First noticed it returning from the gym [about four miles to the house]; speed: "about under 40 MPH"
    :lalala: Ughhh!!!
  2. Oct 30, 2008 at 7:29 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    That should be fine. The manual says you can't but that's nuts. I have a chevelle with posi and its like that all the time damn near a spool. As long as you don't get on it when you turn there should be no linear top speed.
  3. Oct 30, 2008 at 7:29 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    My buddy has traveled with it on in speeds between 35-40mph hes doing fine in his truck.
  4. Oct 30, 2008 at 7:53 AM
    MT_mudflaps
    Clint
    Bellflower, CA
    I certainly hope so gents!
  5. Oct 30, 2008 at 8:06 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    You should be fine.
  6. Oct 30, 2008 at 8:09 AM
    MT_mudflaps
    Clint
    Bellflower, CA
    Yeah, did get to work okay afterwards
  7. Oct 30, 2008 at 8:12 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    :laugh:
    This is why I got a manual... my wife can't drive a stick :D
  8. Oct 30, 2008 at 8:13 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I don't know why they put things like that in the book. I suppose it is to keep people from leaving it locked all the time. Really only hard on the unit when turning under acceleration.
  9. Oct 30, 2008 at 8:35 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    At least you dont have 4wd too.
  10. Oct 30, 2008 at 8:37 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    You also have to realize that it is not meant for dry pavement, regardless of the speed. I doubt that you damaged it much, but if you continued letting your wife drive your truck, then you'll be replacing something pretty soon.
  11. Oct 30, 2008 at 8:55 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    X2. the rear wheels normaly travel diferent distance when turning...inside wheel doesn't have to rotate as many times to go around a corner. when locked on dry pavement there is significant stress put on your third member as the inside wheel wants to turn less than the outside. you'll know if it breaks.
  12. Oct 30, 2008 at 9:23 AM
    MT_mudflaps
    Clint
    Bellflower, CA
    I hear ya guys, and I was concerned about that... I sure hope it doesn't break!!!
    I here both of ya on those accounts!!!
    You know what she had done? She had confussed the rear diff. for the fog light switch -- go figure!
  13. Oct 30, 2008 at 12:24 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    So how does the locker work on the Prerunner? Is it just on or off? On the 4x4 you have to be in 4wLo and stopped for it to engage.
  14. Oct 30, 2008 at 12:37 PM
    MT_mudflaps
    Clint
    Bellflower, CA
    - In Neutral
    - press the "RR DIF LOCK" botton
    - Into Drive
    Operate at 5 MPH or less
    - reverse operations to disengage
  15. Oct 30, 2008 at 11:34 PM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    so by reading this its safe to assume i can get one with 4x4 and rear diff lock? so i can turn off when on pavement and on when in need offroad? or do i have to have one of the trd packages to get rear diff lock??
  16. Oct 30, 2008 at 11:52 PM
    Evil Monkey
    Robert
    Escondido, CA
    For factory, you have to have the TRD Off Road to get the locker. The TRD Sport has limited slip differential (no locker). I think ARB makes an aftermarket locker.
  17. Jan 21, 2010 at 1:46 PM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Hey guys. New to TW. I didn't know that the Sport models didn't have a locker. I'm glad I have the off-road package.
    The last few times I've been out to Ocatillo Wells I've thrown my locker on and left it for most of the weekend. I don't know how well it is at turn off at exactly 5mph, but it does shut off at a certain point. I do try to remember to stop and shut it off before I hop onto the highway, but if I don't I don't worry about it too much.
    Airing up before I left last time, I met another DC owner that said he's made it up Blow Sands (for those who know the area) just by throwing it on. His tires were bigger but they looked almost like street tires.
