What's your MPG?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kayaker7, Jul 19, 2017.
  1. Jul 26, 2017 at 5:57 PM
    #101
    Justinlhc
    Justinlhc Not looking for a relationship
    I wonder how much the lightbar helps?
  2. Jul 26, 2017 at 6:19 PM
    #102
    Default User
    Default User Well-Known Member
    Eric
    Money Pit
    I'm getting about 16MPG On my '12 TRD Sport
    50/50 city/hwy
    Heavy footing it
  3. Jul 26, 2017 at 6:22 PM
    #103
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    That's what's getting him the "ish" part of his 13ish lol
  4. Jul 26, 2017 at 6:32 PM
    #104
    David525
    David525 Active Member
    David
    Colorado Springs, CO
    13 TRD OffRoad Nautical Blue
    Front-Bilstein 5100's set at zero. toytec 620 lb coils springs, Rear-extended Bilstien 5100's (B110), Skyjacker 2 inch add-a-leaf, Firestone ride-rite, daystar cradles,16x8.5 Level-8 Tracker wheels, 265/75-16 Kelly Safari TSR tires, anytime fog light mod, map light mod, scan gauge II, ARE Cx topper, tacoma bed mat, redline tuning hood struts, tekonsha P3 brake control, relocated 7 pin, hidden winch mount, Smittybilt XCR 9.5 winch
    This is the best I have ever got. Was an 80 mile trip running 60-65 mph all highway. 265/75-16 c rated tires. Mid grade fuel. The only thing I do different is I run 1oz super-tech 2-cycle oil per 5 gallons gas. I have been doing the 2-cycle oil for a couple years.
  5. Jul 26, 2017 at 6:45 PM
    #105
    Torquemado
    Torquemado Well-Known Member
    Heart of Texas
    2020 Sport MGM MANUAL
    Under 2000 rpm? Have to try that sometime....
  6. Jul 26, 2017 at 7:07 PM
    #106
    David525
    David
    Yeah barely 65 mph is at 1950 RPM.
  7. Jul 26, 2017 at 7:11 PM
    #107
    igno1tus
    Does your SG mpg match what you actually get at the pump ? Have you compared the 2 ?
  8. Jul 26, 2017 at 7:29 PM
    #108
    David525
    David
    Yes I have compared the two. Its usually 1-2 MPG higher than the actual MPG. Had a couple times it was within a couple tenths. I did not compare this trip.
  9. Jul 26, 2017 at 7:48 PM
    #109
    David525
    David
    Here is my fuelly. The best 25.1 MPG is not correct I had a couple gallons of gas that was getting old and put it in the tacoma and forgot I did when I got fuel a couple weeks later.
    igno1tus likes this.
  10. Jul 26, 2017 at 8:03 PM
    #110
    igno1tus
    I was just curious , a lot post their SG OR UG numbers but I do wonder if those are real world numbers
    I just got a ultra gauge and the first tank it reported 19.7 avg mpg but real world number was 18.85 at the pump which is alittle over 4% off if my math is correct . I do have to calibrate it
  11. Jul 26, 2017 at 8:10 PM
    #111
    RegularTaco
    RegularTaco Well-Known Member
    Drew
    2006 LBZ Duramax
    2006 Chevy Duramax LBZ 2006 Pontiac GTO 2002 TDI VW Jetta 2006 Toyota Tacoma (SOLD)
    Just finished a 2500 mile road trip and averaged 19.3 going 75 mph. Midwest->east coast trip. Hit 20 and 21mpg sometimes and the whole trip i had bf goodrich mud terrain tires on stock black 17" wheels
  12. Jul 26, 2017 at 8:36 PM
    #112
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    65 mph = 2400rpm with a 6speed in 6th
    Scangauge has a 2% odometer correction, and a 10% fuel correction. Matches 50 mile mile marker with 0 error, gas used is only .2 gallon difference with pump on a 20 gallon fill.
  13. Jul 26, 2017 at 9:02 PM
    #113
    igno1tus
    65 at 1950 rpm is for a auto 5 sp trans that's where mine runs at
  14. Jul 26, 2017 at 10:07 PM
    #114
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Go back to stock. Your gas milage will improve. I also put 93 in my tacoma for the first time and oddly I am seeing better MPGs
  15. Jul 27, 2017 at 9:37 AM
    #115
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Somehow squeaked this out last weekend on a 45 min drive to see Dunkirk at the Imax (awesome movie). Granted there was some elevation loss..
  16. Jul 27, 2017 at 2:38 PM
    #116
    jbet49
    jbet49 New Member
    2012 Tacoma
    I'm getting 15+ with my 2012 V6 towing my 3000lb boat with cruise set @ 67 mph
    21+ on the highway...but around town it drops significantly
  17. Jul 27, 2017 at 2:45 PM
    #117
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    When the gauge gets low and the light comes on I either get more gas or stop driving.:facepalm:
  18. Jul 27, 2017 at 3:01 PM
    #118
    92PathSE
    92PathSE Well Known "member"
    GA
    Stock 265x70r16, 4.0, 200 extra pounds of stuff, all city = 17mpg. I did a ton of highway driving a few months ago and it was consistently above 19. I was a little disappointed, but I don't drive it a lot so the added cost per year compared to my old truck is about $30/year.
    edit: I calculate this at the pump. Scan gauges and the like are BS. Then again, the speedo isn't perfect either. I don't care what kind of mpg it gets unless it's off by a large percentage from usual.
    Also, I baby it. I'm going to try driving it harder on the 45mph+ roads to get the TC to lock quicker, just to see what happens.
  19. Jul 27, 2017 at 4:36 PM
    #119
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Totally disagree with your opinion on ScanGauge. Have had mine over 6 years. Followed instructions on how to calibrate it :
    1. Calibrated the SG odometer function to almost zero error - confirmed by both GPS and multiple 50 mile trips by mile marker.
    2. Calibrated the SG fuel used function to less than 1% difference compared to pump.
    Bottom line - almost exactly the same mpg calculated by ScanGauge as calculated by hand. Difference of less than 1%.
    What are you basing your bs opinion on ?
    SpeedwayTaco160 likes this.
  20. Jul 27, 2017 at 6:14 PM
    #120
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I love mine and its accurate for me as well. It's all about proper setup.
