What's your MPGs with 285s and lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muad, Jan 16, 2022.
  1. Jan 16, 2022 at 5:28 AM
    muad
    muad [OP] Member
    Will
    07 SR5 ACLB 4x4 4.0 6MT
    I'm curious what everyone is seeing. My TRD Sport Access cab has a ProComp 6" lift with 285/75/r16s with spacers, and I'm seeing about 14MPG. My work commute is about 20-25 minutes one way with mostly highway/country roads.
    I was hoping for more like 16-17, especially being a manual, but it is winter so that is likely playing a role. Previous owner just did plugs/oil change/new air filter.
    ETA: Oh, and I have the 4.0 V6.
    What are y'all seeing??
  2. Jan 16, 2022 at 6:39 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Ummmmm. You have a 6” lift.with large tires :facepalm:
    Be very happy at that MPG
    refrigerationman, pahaf and wi_taco like this.
  3. Jan 16, 2022 at 6:42 AM
    muad
    muad [OP] Member
    Will
    I get it. Still curious what others are seeing.
  4. Jan 16, 2022 at 6:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Piles of threads on MPG, which all vary greatly based on many factors. (try out the search engine)
    Problem is that your configuration is in the great minority around here, so you won't get many direct comparisons.
    If MPG is important, a truck isn't the place to get it. And a 6" lift with big rubber and stanced geometry don't help. And if it has wheels that weigh a bunch more than stock, that hurts too.
  5. Jan 16, 2022 at 6:52 AM
    muad
    muad [OP] Member
    Will
    I did search and read various threads first, but was curious what those with similar setups were seeing.
    MPG is not 100% important, but when I'm seeing stock config trucks pulling 18-20, it leaves a little to be desired. This is my first truck with a lift, so I'm just curious.
    It still gets 6MPG better than my OBS F350 CCLB 4x4, so I'm happy.
    Good point on the weight of the wheels. I did notice they were very heavy when I was trying to remove my spacers (was chasing a slight steering wheel shake above 50MPG, which I remedied).
    I appreciate the input. Hopefully more with similar setups can chime in.
  6. Jan 16, 2022 at 4:03 PM
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    LT255-80 R17 (33×10). Was getting 12.5 pretty much no matter how/where I drove.
    Recently tried to get a VF tune which "usually" results in improved mileage but the tuner couldn't get my truck to take the tune. In the process it was updated with the most recent Toyota update. My mileage is now running 13.5 city and 15.5 highway. Doesn't make much sense but I'll take it: might check into a tune for your truck, VF and HP both have options available for 2nd gen. (The issue that kept mine from being tuned is supposedly fixed in the next release.)
    muad[OP] likes this.
  7. Jan 16, 2022 at 6:20 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    4 inch lift, 285/70/17- 10ply tires 4.0 automatic in a DCLB and I get 12-14 mpg. I also drive with a pretty heavy foot.
  8. Jan 16, 2022 at 8:20 PM
    muad
    muad [OP] Member
    Will
    Thanks gents. Gonna look into a tune. Are they tuning stock ECUs on these trucks, or does it require a tuner (SCT, etc.)??
  9. Jan 16, 2022 at 10:59 PM
    TacoTuesday1
    SD CA
    weekly Costco gas station Taco Meet
  10. Jan 16, 2022 at 11:57 PM
    Montana_Actual
    Montana_Actual ;)
    13-16 depending on the route, weather, etc etc.. 17 on a perfect flat surface trip, which I never get and never will. That would be like from the gas station to the grocery store in town, which is one mile and 35mph lol. Did a trip home today for 90 miles and average was 15.5.
    From home to town it was like 13. I also had a full bed of stuff probably around 300 pounds.
    I'm on 3" lift w/ e rated 285s and not much weight but I do tuck a full size spare and rim under the bed.
    EDIT
    Oh shit, I'm in the 2g forum... My bad. Looks to be about the same tho
  11. Jan 17, 2022 at 12:02 AM
    092trfe4x45sp
    092trfe4x45sp Active Member
    Lots of added weight, roof racks on a 2.7l and I’m getting 15/16 on my km3’s for most of my driving. I’m sure a lighter tire like the ko2 would give me a little better mpg. If I drop my hwy speed below 75, I can hit closer to 17 on longer trips.
  12. Jan 17, 2022 at 12:44 AM
    fresyota
    fresyota Well-Known Member
    2013 Tacoma Base Access Cab 4x4 2.7 A/T
    14-17 mpg on 285/70r17 with a 2" lift in a 2.7 auto AC.
  13. Jan 17, 2022 at 2:39 PM
    Sarcastro
    Sarcastro Well-Known Member
    Trevor
    2006 Tacoma TRD
    I'm getting 16 mpg with K02 285's and a 3" lift on my 06;TRD Sport. I tested that MPG on a trip to Canada in October
    muad[QUOTED][OP] likes this.
  14. Jan 17, 2022 at 2:58 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    255/85R16 E mud tire (not 285s but still 33s), 6mt with 4.56 gears, with a chonky ass (~6900lbs) and the aerodynamics of a brick I get 13-15.5 mpg depending on weather and speed.
  15. Jan 17, 2022 at 4:57 PM
    xCaldazar
    xCaldazar Well-Known Member
    Los Angeles
    2018 SR5 Purple 4x4
    King shocks, Deaver rear leaf springs, Cab mount relocation, Howe TC Pump, 315/75/17, Outgear tilted rear bumper, Tune Outdoor M1 camper, Coastal Offroad Extreme Clearance front bumper & skids (aluminum), Cali raised kick out sliders, Alphaequipt carbon air intake (color matched) Clazzio leather seat covers, Sound Deadening, Dual battery
    I don't know if this truck previously had a tune. I have 285/75/R16's, stock SR5 rims with spacers and a rough country 3" lift. The best I have gotten babying the fuck out of it was 22 mpg from a tank. I hardly ever went over 65 mpg and did almost no city driving. Fairly flat work commute. I normally get 19 mpg and as low as 15 mpg. I don't drive very aggressively.
