What's your opinion on these tires??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, Feb 25, 2015.
  1. Feb 25, 2015 at 7:26 AM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    P285 70 17 Cooper Discoverer AT3? Should I get the P rated or LT? P rated is only a $150 difference than the LT
    Kumho Road Avengers? P rated same size
    Dueler AT Revo 2? P rated same size
    Any opinions with your experiences with any of these tires are welcome. I also never drive in snow.
  2. Feb 25, 2015 at 8:23 AM
    aubi1414
    Justin
    Pensacola, FL
    nobody?
  3. Feb 25, 2015 at 6:10 PM
    adamax
    adamax Well-Known Member
    adam
    springville ut
    2015 trd off road
    at3 in lt load range c
  4. Feb 25, 2015 at 7:21 PM
    CHEVALIER
    CHEVALIER Member
    Nicholasville KY
    TRD OR
    Weather tech floor liners
    I got the at3 in load range c. If I remember correctly the c range tread depth is deeper than the p rated. We had about a foot of snow last week and I have no complaints with my coopers
  5. Feb 28, 2015 at 6:36 AM
    JPC
    JPC Well-Known Member
    JPC
    Highlands Ranch, CO.
    2011 DC SB TRD 4X4
    5100s front & rear, 2"AAL, KMC XD wheels, Hecuules Tera Trac AT II 265/65/17 tires, ARE Color Matched Topper, Thule Roof Rack, Alpine INE-W940
  6. Feb 28, 2015 at 6:40 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Stay away from the LT load rating unless you tow or haul heavy loads often. They will make your truck ride rough. P or C should be fine, I run P rated Dynapro ATM and they ride really nice.
  7. Feb 28, 2015 at 9:42 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    I can't speak to the Kumho's but I did have a set of the earlier AT Revo's and they were great tires for about 40K. After that they started getting pretty loud. I finally pulled them off the truck after about 45K due to noise. They were still depth wise and had tones of traction in everything I drove in on a daily basis.
    As for P vs LT. Be incredibly honest with yourself. Do you need an LT tire? Do you carry or tow excessive loads? Do you need to extra side all protection? Putting LT tires on is going to make the truck ride stiff. I'll stop short of saying ride like crap but it will be stiff and your mileage will take a pretty good hit due to the extra weight as well. Expect at least a 2mpg drop going to LT tires.
    I'm running Duratrac's in C load and they ride hard even with the pressures dropped to 30 front and 26 in the rear. While I love the tires I'm not sure the ride penalty is worth the extra little bit they give me in traction. I'm contemplating letting them go and moving back to the P265/75/16 Destination AT which I ran for over 80K miles.
