What's your rust removal method?
Discussion in 'Technical Chat' started by CUtacomaTIGER, Feb 19, 2012.
  1. Feb 19, 2012 at 11:04 AM
    CUtacomaTIGER
    CUtacomaTIGER [OP] Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    EDIT: Either for tools or for frame or whatever else
    I've heard/read of:
    lemon juice (citric acid) & salt
    lemon juice (citric acid) & baking soda
    White vinegar (acetic acid) & salt
    White vinegar (acetic acid) & baking soda
    WD-40 (water displacement perfected on 40th try)
    Then you scrub with some steel wool or what not. Neutralize solution with some soapy water or baking soda and dry. Then put some WD-40, oil, or some other rust inhibitor to protect.
  2. Feb 19, 2012 at 11:09 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I used wire wheels on a drill and 80 grit sandpaper where I couldn't fit the driill, followed by Zero rust paint on my frame. Zero rust requires minimal prep work, just spray with water and let it dry 24 hours. It has held up pretty well so far. Definitely better then the areas I did with wire wheels/ 80 grit, laquer thinner and rustoleum.
  3. May 27, 2012 at 2:39 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Ospho is good. It is phosphoric and other acids. Turns the rust white. It changes from iron oxide to magnetite, so it's actually not rust anymore. Ospho can be found at the auto parts or hardware store. It's also called metal prep used by restoration and body shops. Just spray it on with a spray bottle...wear gloves though.
    WD-40 and Rustoleum are both fish oil based, it stops rust.
  4. May 27, 2012 at 2:51 PM
    hornytoad
    hornytoad fisherman
    west texas
    96 tacoma sr5 4x4
    +1 ospho can b applied with brush also
