Whattttts That Sound?
Discussion in '1st Gen. Tacomas (1995-2004)' started by REDeye jedi, Mar 7, 2020.
  1. Mar 10, 2020 at 9:38 AM
    #41
    REDeye jedi
    REDeye jedi [OP] Well-Known Member
    Brendan
    Palm Springs
    2001 Tacoma prerunner 3.4l
    Awesome. Thanks. Ill test this out later. Its raining pretty good at the moment.
    cruiserguy likes this.
  2. Mar 10, 2020 at 9:49 AM
    #42
    REDeye jedi
    Brendan
    Palm Springs
    Hmmm. Well thats not it then. Had fan OFF switched to vent and feet and still heard it. Put the ac on and waited for compressor to kick in and still heard it.
  3. Mar 10, 2020 at 10:46 AM
    #43
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That's good info to know/have.
    Still could be from the compressor, you can remove the belts, one at a time and start the engine and see if it's still there.
    100% positive it's coming from that compressor though? How about the tensioner pulley or idler pulley thing that the AC belt uses as well. Could that be the source of the noise? I
    Next would be to loosen a couple of the bolts and pull the belt off. And see if noise stops then
  4. Mar 10, 2020 at 2:12 PM
    #44
    REDeye jedi
    Brendan
    Palm Springs
    Ok. So im not 100% its coming from their but when i put the stethescope on each piece that a pulley us attached. I was hearing it from the compressor.
    So i should stary by taking the belt thats attwched to the ac compressor pulley? If the sound stops. Thats the source? If i still hear it, then take off each belt one by one to see if the sound stops?
  5. Mar 10, 2020 at 2:21 PM
    #45
    cruiserguy
    Elijah
    SEKS
    Yeah, that's the idea. Keep in mind you may end up removing the belt drives the waterpump and so you'll want to just start it and listen for your noise(or lack thereof) and turn it off, since coolant won't be circulating without that belt on it. You can run the engine for a half minute without worries that way.
    We want to identify which belt/component the noise is coming from, then we'll narrow down which component within that belt system is the culprit
  6. Mar 10, 2020 at 2:41 PM
    #46
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    waterpump is driven by timing belt. he's safe.
    REDeye jedi[OP] and cruiserguy like this.
  7. Mar 10, 2020 at 2:43 PM
    #47
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    oh boy! I love this game! I play it everytime i get inside my truck
  8. Mar 10, 2020 at 2:43 PM
    #48
    cruxofthebisquit
    Orange Texas
    2000 TRD
    You just have the 2 belts. Just take them both off. Then you can spin everything and compare. Said it before....turn the fan and listen carefully to the bearing behind it.
    edit: Hell, take the fan off and spin bearing.
  9. Mar 10, 2020 at 2:44 PM
    #49
    cruxofthebisquit
    Orange Texas
    2000 TRD
    laughs.
    The 'What's that new sound?' game? Yea, part of having an old car.
    REDeye jedi[OP] likes this.
  10. Mar 10, 2020 at 2:51 PM
    #50
    cruiserguy
    Elijah
    SEKS
    D'oh! :homer: Totally spaced that he was the V6. Thanks for the reminder :D
  11. Mar 10, 2020 at 3:02 PM
    #51
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Exactly! even though i changed them less than 6 months ago, right now I feel i have a wheel bearing acting up.. I hear a rotational squeak that only occurs when the truck is driven for a minute and it is subtle enough where i can only hear it if i am close to a wall where it can reverb off.
  12. Mar 10, 2020 at 3:05 PM
    #52
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Dude!!! Same.
    I just quit driving it unless I have to.
  13. Mar 10, 2020 at 3:18 PM
    #53
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    New seals and prepressed bearings... what are the chances? hahaha
  14. Mar 10, 2020 at 3:20 PM
    #54
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Good chance it's something else. I have mine narrowed down to 'underneath'.
  15. Mar 10, 2020 at 3:41 PM
    #55
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    yup! mine is narrowed down to "rotational" the rest is speculation hahah
  16. Mar 29, 2020 at 1:48 PM
    #56
    REDeye jedi
    Brendan
    Palm Springs
    Ok guys. So quick update. I found the problem. Its coming from the ac compressor tension pully. Now to figure out a fix. thanks for all the suggestions.
  17. Mar 29, 2020 at 2:15 PM
    #57
    REDeye jedi
    Brendan
    Palm Springs
    I'm not even sure if I'm calling it the right name because I'm not finding much online. If you listen closely you can hear the bad bearing.
    https://youtu.be/8w5tqHIElS4
  18. Mar 29, 2020 at 8:30 PM
    #58
    cruxofthebisquit
    Orange Texas
    2000 TRD
  19. Mar 29, 2020 at 8:33 PM
    #59
    REDeye jedi
    Brendan
    Palm Springs
    so I actually just ordered a oem bearing 6301 and going to just do the bearing replacement and save me $30. Saw a couple videos and it looks pretty simple
  20. Mar 29, 2020 at 8:42 PM
    #60
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yes, at the point you have it, it's cake from here.
