What’s the best front LED light bar setup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VicNic3, Jan 1, 2021.
  1. Jan 9, 2021 at 2:18 PM
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    BFD204AF-4F23-4555-896E-D70AE9BC9269.jpg Diode Dynamics combo bar in amber.
  2. Jan 9, 2021 at 2:23 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I was that jackass one night. I came off a trail at around 9pm that fed off straight onto the freeway. I had all front leds on and forgot to the turn them off when I get on the road. As I was coming up behind to another truck, I could see the guy was flipping out in the cab. He was waving his arms, middle fingering and slowed suddenly to get behind me. Then started flashing his high beams on and off. I was thinking what in the f*** is this guy's problem? What a maniac. Then realized I had left on all my bumper/grill lights. Oops
    helix66 likes this.
  3. Jan 9, 2021 at 2:25 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    I found a spartanX grill and scoop light cheap on FB marketplace from a lease turn in. With my rigid pod fogs. Soon Ill have some OEM LED headlights and a BD 30" bar in my SSO slimline to add to the lightshow.
  4. Jan 9, 2021 at 5:53 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Do you have the stock rear bumper?
    Where were you going to cut them in?
    I want to get lights in it but also want to get a high clearance at some point.
    Are you all just using the oem style switches? I’m hoping to avoid a wiring mess.
  5. Jan 9, 2021 at 7:50 PM
    BroncoAZ
    BroncoAZ Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
    I’ve got the stock rear bumper, and the truck is a lease so I don’t want to cut them in. I haven’t looked at the hitch yet to see where I can mount lights. The BD S1 would be my first choice. The reverse lights would be wired off the 7 pin reverse light circuit and I would use the factory wiring for fogs. A light bar would need a factory style switch.
    helix66[QUOTED] likes this.
  6. Jan 9, 2021 at 8:34 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Wondering which is brighter the cali raised or the diode dynamics. Having the DD fog lights I assume they’re better but who knows
    I have so much stuff in the garage that I never installed, or took off.
    OMGitsme[QUOTED] likes this.
  7. Jan 9, 2021 at 9:12 PM
    Koolbreeze7
    Jon
    Jersey
    Im planning to keep mine with the SSO slimline and hoop. I think it will remain mostly unblocked as I mocked it up
    OMGitsme likes this.
  8. Jan 9, 2021 at 9:32 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I like the two smaller lights with the forward camera in between. Not for everyone, I understand.
  9. Jan 9, 2021 at 10:44 PM
    Thejohnnyb21
    Thejohnnyb21 Well-Known Member
    Johnny
    Pasadena, CA
    21' AG Tacoma TRD OR
    Cali Raised Combo :thumbsup:
    WELLSPRING likes this.
  10. Jan 10, 2021 at 9:12 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    How are you tapping into power for the light and even the switch?
    I think @MESO has a hitch mount for one of the small BD lights. Not sure if it's in production or was a prototype.
  11. Jan 10, 2021 at 9:21 AM
    BroncoAZ
    Cape Cod, MA
    Are you asking about power for the light bar, or the reverse lights? For the reverse lights the 7 pin connector provides a switched output that can power a couple of LED’s. I usually make a relay setup to prevent backfeed with a separate switch mounted in the bed for running the lights manually when camping. I have also tapped the reverse light wire at the taillight to get the switched lead on other trucks. The 7 pin has a charging lead for the trailer that should provide power, or I can run a wire if needed. For the light bar I would go direct to the battery and install a switch inside, I’d probably want to hook up a relay to have the light bar enabled by the switch but activated by the factory high beams. I think it’d be sick to have the light bar work with the auto high beams.
    I saw that thread on the MESO single pod, looks promising and should be enough light. In the past I’ve made brackets or drilled a single hole (per light) in the hitch to mount lights.
  12. Jan 10, 2021 at 9:46 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    The only issue with the hitch is someone could bump into it.
    I was asking about the connectors you used for power for the light bar and even the backlight for the switch.
    Add-a-fuse and those vampire taps
  13. Jan 13, 2021 at 8:31 AM
    MMASWO89
    MMASWO89 New Member
    Kurt
    2021 Toyota Tacoma TRD Sport, Cement
    How much did you have to trim off the panels? Do you have any pics? Light bar and brackets arrive Friday and I would like to reinstall the plastic air dams too. Thanks!
  14. Jan 13, 2021 at 8:46 AM
    Miles009
    Miles009 Well-Known Member
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    I went diode Dynamics stealth 30in amber combo (fog/driving) . I paired them with the ss3 pro white driving fogs.
    If you want install tips lemme know.
    Installation was straight forward for me. 2-3hr install from pulling truck in to tool clean up....while drinking morning coffee (substitute for beer if evening and add 30min)
    tacospecial and tclavell like this.
  15. Jan 13, 2021 at 8:48 AM
    #35
    Miles009
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    What fogs did you go with?
  16. Jan 13, 2021 at 8:50 AM
    #36
    Miles009
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    I have diode Dynamics 30in amber combo. I can take a lux meter to it if anyone is interested
    oyemengitsamie likes this.
  17. Jan 13, 2021 at 8:52 AM
    #37
    oyemengitsamie
    oyemengitsamie amie.
    Gainesville, FL
    2020 Toyota Tacoma SR V6 4x4 in MGM
    I believe those are DD as well.
  18. Jan 13, 2021 at 8:52 AM
    #38
    tclavell
    Troy
    Phoenix, AZ
    G70
    perfect setup in my opinion! I just reversed what you did. I went with the white combo stealth 30" inch light bar and SS3 Sport fogs.
  19. Jan 13, 2021 at 8:53 AM
    #39
    oyemengitsamie
    Gainesville, FL
    pics?
  20. Jan 13, 2021 at 8:54 AM
    #40
    tclavell
    Troy
    Phoenix, AZ
    G70
    A71C2688-1E6D-4432-912C-EDD1EC89AE26.jpg E4F14C68-905B-4DE8-990D-C562C9F18830.jpg
    Miles009 likes this.
