wheel adapter 5-lug to 6-lug conversion
Discussion in '5 Lug' started by duyphung, Jun 29, 2009.
  1. Jun 29, 2009 at 7:19 AM
    duyphung
    duyphung [OP] New Member
    08 tacoma base
    [​IMG] wheel adapter 5-lug to 6-lug tacoma
    What's up TW?! I was wondering if any of you know if it's possible to convert my 2008 base model tacoma 5-lug 215/70/15 wheels to a 6-lug so I can fit the TRD sport wheels 265/70/17? Let me know where is a good place to get these adapters. I just purchased. Also if you guys know if the TPMS sensors will fit from the 15" wheels to the 17" wheels. Any helpful information would be appreciated :D
    thanks,
    Dewey
  2. Sep 24, 2010 at 6:27 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    Adaptors=death
  3. Oct 26, 2010 at 8:10 PM
    aggiepack
    aggiepack Well-Known Member
    Nate
    [**SOLD**] '08 Super White reg. cab waiting for the '16
    Fat Bob's 5 lug 2."75" Lift Kit, Fat Bob's Performance 8000 Rear Shocks, 235/75/15 BFG A/T tires, UWS Low Profile Tool Box, AVID Off Road Sliders, Chrome Grille Assembly, Fog Lights, Black badges, Tinted Rear Window, TRD Bed Mat, TRD Off Road Floor Mats, Maglite Mount, CoverKing Seat Covers
    i was in your same situation a couple months ago (I myself have a '08 reg cab). i've heard some sketch stuff about adapter safety and finding a reliable company to buy them from. if you've got a 4x2 reg cab putting those on may be a really tight fit too (you can always remove the black box if you wanted to though). I ended up getting 17" black motor sport rims over at America's Tires (they look great might I add), but just switched back to the stock rims with 235 bfg's (liked this look more - time to find some nice 15"s now)
    Back to the point: it's safer and dare i say "easier" to find a nice looking 16 or 17" 5 lug rim and is probably going to be less expensive after calculating adapters for the 4 wheels. Those tires will probably stick out the side too might I add (if you like the look then more power to ya!) Hope this helps with your decision!
  4. Oct 26, 2010 at 8:40 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Don't hide your 5 lugginess... Embrace it!
  5. Oct 26, 2010 at 8:42 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    dont be hating on the 5 lugs, Im one right now on one wheel
  6. Oct 31, 2010 at 5:37 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Dewey:
    First off Welcome to TW.
    As others have said an adapter is not the way to go.
    With the TPMS the wheel material type determines the TPMS sender. Our Tacoma's come with steel wheels and the TPMS senders are not compatable with an alloy wheel. If you purchase an alloy wheel you will need to factor in new TPMS senders and a reprogram so your Tacoma can receive the signal from the new sender.
    I bought a set of wheels and tires this past summer from Discount tire direct. They were easy to deal with and I had no problems.
    http://www.discounttiredirect.com/d..._kwcid=TC|5865|discount tires||S|p|5849265971
  7. Oct 31, 2010 at 10:43 PM
    jfred90
    jfred90 Member
    Sacramento, CA
    '09 Access Cab SR5 - 5 Lug
    I've heard parts of this before but here's my experience....
    I put a small lift on mine (equivalent to the 5-Lug ReadyLift kit) and put on Pro Comp 7089's (aluminum alloy wheels). 4 Wheel Parts was able to put my TPMS sensors in the new wheels with no issue.
    I've read the reason the reason they sometimes wont fit has to do with the valve stem angle, but I cannot confirm if this is true or not. The tire shop should be able to tell you if they will work in the wheels you want.
  8. Nov 1, 2010 at 4:09 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Nice information. At close to $60 a sensor if you can reuse the factory sensor that would be a nice savings.
  9. Dec 14, 2010 at 4:23 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    what is the black box? I have a 07 Base Model AC and I am planning on dropping it.
  10. Dec 14, 2010 at 5:31 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    it sits behind the fender liner on the side closest to the door. if you check harrelsen's (sp?) build thread i think he has a pic of it cut out.
  11. Dec 14, 2010 at 8:32 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Here is the thread (with pictures) about the black box mod.
  12. Dec 14, 2010 at 10:25 AM
    07TacoRidah
    cool thanks guys. I may have had problems with this due to my tire size (I am curently running 235/60/R18).
  13. Dec 14, 2010 at 10:46 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Don't be so sure I bought some Ebay 1-1/4" spacers and ran em on the front of my 05 till I got my Long travel.
    Worked fine just put some thread locker on the lugs and checked them every time I did a service then never came loose at all even after doing this few times
  14. Dec 14, 2010 at 11:27 AM
    07TacoRidah
    from what I was told about adapters, they HAVE to be Billet type. nothing else.
  15. Dec 14, 2010 at 11:33 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    That's what mine where and I only paid like 60 bucks :)
  16. Dec 14, 2010 at 11:36 AM
    07TacoRidah
    FAWK !!!!!!!! ALL of the places I have looked they are selling them for maybe 60 EA. or worse off about $200 or so plus shipping. Yours is a 6 lug no? Maybe that is why you got them for the $60 ... will have to look into that. 6 lug rims are EXTREMELY CHEAP these days.
    BTW, do you have the name or link to the Ebay store?
  17. Dec 14, 2010 at 11:49 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    No sorry it was a looooong time ago just check out ebay I'm sure you find some good ones
