Wheel adapter questions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Double O’ Taco, Oct 21, 2024.
  1. Oct 21, 2024 at 8:10 AM
    Double O’ Taco
    Double O’ Taco [OP] Well-Known Member
    Paul
    2000 Tacoma V6 5spd 4x4 club cab sr5
    Lift, wheels, leds, grey wire mod, E150 rear springs, antennas, subs, etc…
    I recently bought some 18x9 wheels for my Tacoma off of someone I know and trust and he was told they were off a Chevy but after I tried to put them on they turned out to be for an f-150, I still want to run them as I’m $350 into them with near new tires on all four so can I buy some adapters for a Silverado to ford use and have my machinist buddy bore the inner hub to the correct 106mm fit my truck and will I run into issues with the lug nuts seating on the axle side since the adapter is for m14x1.5 threads and my axle has m12x1.5
    Or should I buy some non hub centric adapters with a 108mm inner bore and m12x1.5 threads and machine a press fit insert to put into the adapters that has the fords 87.1mm hub and then weld in the inserts to the adapter.
    I just want to ask before I do anything as I don’t want to waste my money or have my wheels fall off.
    Also how do I cheaply correct my speedometer for the tire size difference.
  2. Oct 21, 2024 at 9:27 AM
    02hilux
    Planet: EARTH
    Personally, ask your friends for a refund. If not, sell it and save yourself the trouble.
    SH10151, Clearwater Bill and YF_Ryan like this.
  3. Oct 21, 2024 at 9:46 AM
    Double O’ Taco
    Paul
    That’s what I’m going to do if I can’t make it work, but I’m asking how to make it work best.
  4. Oct 21, 2024 at 10:10 AM
    PathFinder1776
    PathFinder1776 Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    Get rid of them and get ones that fit. It will cost more to make them fit than to get something that actually works correctly.
  5. Oct 21, 2024 at 10:15 AM
    Double O’ Taco
    Paul
    Where am I going to find wheels and tires like that for that price? The adapters are $115 for four and I have $350 into the wheels and near new tires.
  6. Oct 21, 2024 at 10:19 AM
    PathFinder1776
    Marketplace. Keep the tires and watch for new wheels.
  7. Oct 21, 2024 at 11:08 AM
    Double O’ Taco
    Paul
    18s are scarce where I live unless they are Silverado stocks, that is why I want to try this.
    Also on another note even if I find wheels with the right lug pattern I will still have to buy adapters to get the right hub size. People near me want $1,500 for a set of four rims that will work on my 106mm hubs and I can’t afford that
  8. Oct 21, 2024 at 11:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is the easiest way.
    Most wheel spacers use conical seat lug nuts on the vehicle hub side, so M12 conical seat lugnuts should work.
    What offset are the Ford wheels and how thick of an adapter are you planning to use? If the adapter is less than 1.25", make sure the wheel has relief pockets between lug holes to accommodate stud protrusion.
  9. Oct 21, 2024 at 11:34 AM
    Double O’ Taco
    Paul
    I plan to use a 1.5” adapter, I don’t know the offset but it looks like it is about 4.5 from the front lip to the mounting flange
  10. Oct 21, 2024 at 2:14 PM
    Double O’ Taco
    Paul
    Never mind It quit raining and the backspacing now that I checked is the same as my old rims.
  11. Oct 24, 2024 at 2:51 PM
    Double O’ Taco
    Paul
    Okay adapters have been ordered and just in time as I finally swapped to the wheels and tires off a 98 4Runner in parting out and it turns out my highway vibration is from one of the old wheels.
  12. Oct 24, 2024 at 2:52 PM
    Double O’ Taco
    Paul
    Forgot to mention why it was shaking, it is slightly bent but still in balance somehow so the tire shop never noticed.
  13. Oct 24, 2024 at 2:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Hope you knocked some points off his 'trust' cred.
    Ever heard the phrase trust but verify? Now you have an exemplar.
  14. Oct 24, 2024 at 5:09 PM
    Double O’ Taco
    Paul
    No I trust the dude more than my own family as he has proven himself trustworthy
  15. Oct 26, 2024 at 8:19 AM
    Double O’ Taco
    Paul
    He’s a Cuban immigrant who has been here in the US for over 35 years and thinks of me like the son he never had, he has had so many opportunities to scam me or screw me out of my money and never has.
  16. Oct 26, 2024 at 8:28 AM
    Glamisman
    Glamisman Well-Known Member
    Couple of things.
    Thing 1: An honest mistake was made, see if he will make it right, if not, not sure to tell you how to proceed with that.
    Not all wheels are the same. Toyotas are different. So, even if you got adapters to fit them they would probably vibrate.
    Thing 2: https://www.discounttire.com/learn/hub-centric-vs-lug-centric
  17. Oct 26, 2024 at 8:51 AM
    Double O’ Taco
    Paul
    I got some adapters that are hub centric but they have the wrong inner hub diameter for $110 and I have a machinist friend that will machine out the inner hub from the Silverado hub size to the correct 106mm for my Tacoma.
    I am going this route as I didn’t want to get some adapters custom made for $350-$500 as I don’t have that kind of money just laying around.
  18. Oct 26, 2024 at 8:56 AM
    Double O’ Taco
    Paul
    Read the linked stuff and thanks for the info, I did measure a while back and these wheels are actually hub centric which is another reason why I want to have a hub centric adapter as well as how much I use this truck as a truck, to do truck stuff like hauling and towing.
  19. Oct 26, 2024 at 12:16 PM
    Glamisman
    Ok, seems like you researched and thought this out more than my inital read of your post #1... good luck.
    cruiserguy likes this.
  20. Oct 27, 2024 at 8:19 AM
    Double O’ Taco
    Paul
    Yeah this is the average reaction to my ideas, I don’t present them in a way that makes it seem like I did some thinking about it beforehand.
