Wheel Adapters
Discussion in '5 Lug' started by 2007 4x4, Feb 4, 2019.
  1. Feb 4, 2019 at 6:49 AM
    2007 4x4
    2007 4x4 [OP] Well-Known Member
    07 4x4 DCLB SR5 and 06 Reg Cab 5 Lug
  2. Feb 4, 2019 at 6:54 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I run wheel spacers which are practically the same.
    I think some guys on here run 5lug to 6lug adaptors
  3. Feb 4, 2019 at 3:23 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Do I recommend them? No, but you'll be fine. @5 Lug Fury is running 5 to 6 adapters in the rear. Just follow specs and don't overtorque.
  4. Feb 4, 2019 at 6:48 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    They are a pain in the ass to remove though just a heads up
  5. Feb 5, 2019 at 5:15 AM
    2007 4x4
    Thanks guys - I might give it a try.
    See below specs of the Ones I am looking at - my question is if I will need hubcentric rings?
    - Wheel Stud Length: Your vehicle's wheel studs need to be less than 1.0" (25mm). If not, the back of your wheels need pockets long/wide enough for your studs.
    - Fender Gap: Measure your wheel gap for clearance. You will need at least 1.0" (25mm) of fender clearance to prevent the wheel/tire from hitting the fenderliner.
    - If your vehicle hub is smaller than 73.1mm, we recommend purchasing hubcentric rings to reduce the chance of vibrations.
    - If your vehicle doesn't come with 12x1.5 threaded studs, additional hardware will be required. Message us for help.
    - No Returns or Exchanges once installed.
    https://www.amazon.com/Adapters-5x114-3-CHANGES-PATTERN-Spacers/dp/B00HQSQO4A
