Wheel advice (Fitment)
Discussion in 'Wheels & Tires' started by Rellik01, Dec 26, 2011.
  1. Dec 26, 2011 at 4:50 PM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    I love these rims but am afraid to pull the trigger as I am very confused about the different specs. I searched and looked at the stickies but still confusing for a novice.
    Could one of the resident experts reassure me that these will fit with no problem with stock 265/65/17 tires no lift 2011 TRD Sport 2wd.
    XD797 Spy - Gloss Black Machined Wheel by XD Series - W/P79778068318
    • 17x8 wheel size
    • 6 on 5.5 bolt pattern
    • Backspace = 5.21in.
    • Max Load = 2200lbs
    • Finish = Gloss Black Machined Face
    • Hubcentric = No
    • Offset = 18mm
  2. Dec 26, 2011 at 11:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    with stock sizing you will be fine.
  3. Dec 27, 2011 at 1:22 PM
    Rellik01
    Craig
    Windermere, Florida
    Stock tires, Stock suspension, rubbing of calipers. You suggest all no problems. Thanks for advice.
  4. Dec 27, 2011 at 2:59 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    correct. once you start going with bigger tires is when you might run into rubbing problems. this particular wheel has a lot of backspacing, but if you stick with a stock sized tire or plus 1 sizing, you'll be fine.
  5. Dec 27, 2011 at 5:32 PM
    Rellik01
    Craig
    Windermere, Florida
    Great, thanks for the reply
  6. Dec 28, 2011 at 12:41 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    Just for info, i just got at 17x8 weel with a 5.0 backspacing on a 265/70/17 hankook MT n it rubs. Im going to bring it to the shop tomorrow n theyre going to add spacers ill let u know if that fixes it.
