Wheel and Spacer Related Dimensions Needed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by weldo, Feb 15, 2015.
  1. Feb 15, 2015 at 2:32 PM
    weldo
    weldo [OP] Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey guys, I need some accurate dimensions in the wheel area. I know the center bore of Tacoma wheel should be 106mm but has anyone taken an accurate, caliper or micrometer measurement of it?
    I ask because I need to get a set of aftermarket alloy rims bored out and I'm not sure if I should go 106mm exactly or allow a tiny bit of clearance.
    I recently picked up a used set of 1.25" wheel spacers made by G2 Axle to use with the new set of wheels. They appear to be well made, although made in China. When I measure the counter bore on the spacers I get about 106.3mm. When I measure the snout or hubcentric ring the wheel slips over, I get about 105.8mm.
    So is this discrepancy normal for wheel spacers to make sure the wheels are not too tight of a fit on the hub, or are mine out of spec because they are made in China?
    Anyone with Spidertrax, Bora, or Allpro spacers, I'd super appreciate it if you could get some accurate dimensions for me.
    I could also use dimensions of the wheel hubcentric ring on the truck or a center bore of a factory alloy rim. If anyone has an old hub or a set of wheels lying around the garage, I could really use a few numbers.
    Thanks a bunch fellas!
  2. Feb 16, 2015 at 3:25 AM
    weldo
    Pittsburgh, pa
    Anyone have time to check this?
