Wheel and tire help please...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mtbkman, Dec 23, 2023.
  1. Dec 23, 2023 at 9:08 PM
    mtbkman
    mtbkman [OP] 2020 TRD Sport
    Metro Detroit
    2020 Trd Sport MT
    None yet
    Hi,
    I have a 2020 TRD sport with stock suspension and wheels. 265/65/17. Looking at going with some Nomad Wheels. Was originally going to do 17 x 8.5 0 offset with 265/70/17. Now I'm kind of thinking maybe the 16 x 8 -10 offset with 265/75/16 to have more rubber and less wheel. Planning on keeping Stock suspension. Will the -10 offset on the 16's be an issue?
  2. Dec 23, 2023 at 9:38 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    On a side note, you might also want to look into what tires and load rating you want. I wanted 16's but the tires I wanted only came in E unless if I went with 17's. There are more C tire options in 17
    Chew likes this.
  3. Dec 24, 2023 at 5:19 AM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Also make sure a 16” wheel is going to clear the brake calipers on the sport
    LOLLY likes this.
  4. Dec 24, 2023 at 9:35 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You will most likely have to trim with -10 offset.
    mtbkman[OP] likes this.
  5. Dec 24, 2023 at 2:05 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    16" is the right size for a Taco... that is my take on that.
