Wheel and tire Help.
Discussion in 'Wheels & Tires' started by pdubbz31, May 12, 2008.
  1. May 12, 2008 at 5:36 PM
    pdubbz31
    pdubbz31 [OP] Member
    07 4x4 Tacoma SR5
    So, this is my first time buying Wheels and tires, i just want to make sure that this set up will fit.
    I drive an 07 Double Cab.
    I also have a revtek 3" lift.
    I am hoping to go with this following set up.
    Pro Comp Xtreme Mud Terrain... LT285/75/R16
    Moto Metal 951 BLACK...16x9, 6 on 5.5 /Bolt Pattern
    Offset = -12 mm
    Back Spacing = 4.53 inch
    Hub Bore = 108
    Do you think i would run into any problems?
  2. May 12, 2008 at 6:13 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if nothing else, i'm sure u'll either have to remove the mudflaps or trim them down at the least, b/c i'm sure ur gonna get some rubbing
  3. May 12, 2008 at 6:16 PM
    pdubbz31
    07 4x4 Tacoma SR5
    Ive already removed them haha.
    thanks for the response.
  4. May 13, 2008 at 7:22 PM
    Rockstar2448
    Rockstar2448 Well-Known Member
    Maryland
    05 Indigo Ink TRD Sport D-Cab LB 4x4 // 2020 Super White TRD Sport D-Cab LB 4x4
    2005: Toytec 3" Lift, Helo Maxx6 Chrome 17x8, Nitto Terra Grappler 265/70/17, Polished Billet Grill-Full Front Kit, Westin Polished SS Tube Steps, Leer 700 Tonneau, Fog Lights On Anytime, Debadged, USA Spec iPod Adapter, Britax car seat with special UNC color scheme, Window Tint, SilverStar bulbs 2020: TRD Skid Plate with front spoiler delete, emblems partial removal/blackout, Toyota folding hard tonneau
    I'm running 265's on 17 inch wheels and I have a rub on the passenger front inner fender well, so my guess is, you're going to have some rubbing in the fender wells too. Get a sharp blade or hand saw and prepare to do a little shaving :)
  5. May 13, 2008 at 7:27 PM
    The_Hodge
    SC
    the sports come w/ the 265/65/17's stock...its not that 265 thats causing the rub....u moved up to a 265/70 and that extra 1" or so of height is making it rub.
  6. May 13, 2008 at 10:43 PM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    i have read this many other places also but 265/75/16s do not rub at all and this is before my skyjacker 2.5-3" lift without tsb.
  7. May 13, 2008 at 10:46 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    my 265-70R17's used to rub on the little bulge inside the front of the passenger side fender well too...... only on full lock to the left and backing up, at least until i ripped that whole cheesy plastic bumper off:D
  8. May 13, 2008 at 10:47 PM
    RelentlessFab
    Eric
    Sparks, NV
    stock wheel? if so, then thats why. Aftermarket is typically wider offset and gives a larger steering arc that the tire travels, thus leading to the rubbing.
  9. May 13, 2008 at 10:56 PM
    jtaco
    oooohhh yea ok
