wheel and tire help
Discussion in 'Wheels & Tires' started by ben26416, May 16, 2010.
  1. May 16, 2010 at 1:41 PM
    ben26416
    ben26416 [OP] Well-Known Member
    WV
    2010 Tacoma DC 4x4
    Flowmaster duals, Avid Off Road Steps
  2. May 16, 2010 at 2:00 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Anytime there's a different diameter it'll change. That said from the factory its a 5% range of accuracy, so if your worried about tickets and such, don't! You will be fine. That's such a miniscule difference
  3. May 16, 2010 at 2:41 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There's definately variability between different tire manufacturers, even though the tires are labeled as the same size.
    It surprises me that the coopers are 3/4" shorter than the stock 265/70/16's though. That's a fairly large difference. Were the stock tires new and the coopers fairly used?
  4. May 16, 2010 at 7:25 PM
    ben26416
    WV
    2010 Tacoma DC 4x4
    My truck has about 600 miles on it, so the stock tires are pretty much brand new. The coopers are new as well, but they are on 8" rims while the stock wheels are 7". That is the only difference that I can think of that would make the coopers shorter.
  5. May 17, 2010 at 5:57 AM
    KPT
    09 Prerunner
    I wouldn't think that the rim width would change the tire diameter. It would have a minor effect on the tire width.
