wheel and tire setup questions (rubbing)
Discussion in 'Wheels & Tires' started by Seth_muehlstein, Feb 1, 2020.
  1. Feb 1, 2020 at 9:36 AM
    Seth_muehlstein
    Seth_muehlstein [OP] Member
    Seth
    2017 white TRD Off-Road
    I recently put on a 2 inch leveling kit on the front of my 2017 TRD Off-Road and I am wanting to put some new wheels and tires on my truck. I would like to get 285/75/r16 Toyo open country M/T tires and The wheels I want are the Method 305 | NV | Matte Black but they only come in a 0 offset and 4.5 backspacing in the 16in diameter. I was wanting to know if I could fit that setup on my truck with no/minimal rubbing. I don't mind cutting some plastic but I don't really want to do a CMC yet. Would I need tobuy a set of 1.25 wheel spacer? Anyfeedback will be greatly appreciated!!
  2. Feb 1, 2020 at 3:48 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You won’t need the spacer. That would make any rubbing issues worse. Hopefully some 3rd gen guys will chime in on the size fitment.
  3. Feb 1, 2020 at 5:08 PM
    Seth_muehlstein
    Seth
    Oh ok thanks for the info!!
  4. Feb 3, 2020 at 8:39 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Steve is correct, the spacers will push the wheels further out which will increase the possibility of rubbing the cab mount. 285's are aggressive to begin with on your generation so for 285's you'll likely have to do the CMC.
  5. Feb 3, 2020 at 4:56 PM
    Seth_muehlstein
    Seth
    Thanks for the info I will most likely end up doing a CMC.
    Discount Tire likes this.
