Wheel and tire size Question
Discussion in '5 Lug' started by SuperchargedFX, Jan 2, 2013.
  1. Jan 2, 2013 at 4:34 PM
    SuperchargedFX
    SuperchargedFX [OP] Member
    Jericho
    NOR*CAL
    05 Single Cab
    none :(
    Hey guys just need something clarified im planning to buy some wheels, the pro comp series 51/52 to be specific. Im pretty sure the 15x8 5x4.5 -19mm offset and 3.75 backspace will fit the 2005 up tacos. The question i was wondering how far they will stick out from the wheel wells? and what the biggest tire size i can fit on there also? 225/70/15? (probably going to take out the black box)
  2. Jan 3, 2013 at 9:28 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    any plans on lifting?
  3. Jan 3, 2013 at 10:11 PM
    SuperchargedFX
    Jericho
    NOR*CAL
    05 Single Cab
    none :(
    Sometime down the road. So not right away. Will this setup only work with a lifted taco?
    thanks for the reply
  4. Jan 4, 2013 at 1:13 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    If you plan on lifting later id do a 30x9.5
  5. Jan 4, 2013 at 2:56 AM
    SuperchargedFX
    Jericho
    NOR*CAL
    05 Single Cab
    none :(
    Oh ok and those will fit without rubbing if i take out the black box? Also the wheels will fit without spacers correct, i went to a nearby 4 wheel parts and they said it might rub the brake calipers, but im seeing a bunch of threads with 2005+ tacos with these rims not using spacers just want to clarify.
    thanks again
  6. Jan 4, 2013 at 9:18 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Im pretty sure if you ditch the black boxes you can run a 30x9.5 no problem as for the wheels theres a few 5 lug builds that use those types of steelies with no issues. Id double check that first before you drop the coin
