wheel at full lock question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Haikin, Apr 8, 2018.
  1. Apr 8, 2018 at 2:47 PM
    Haikin
    Haikin [OP] Well-Known Member
    I initially thought it was the sway bar end link, but it is definitely coming from the steering rack. The steering rack bushing bolt was nice and tight. Also, the noise was coming from the passenger side. Any advice would be greatly appreciated.
  2. Apr 8, 2018 at 4:09 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Check the LCA bolts; cams might be hopping the alignment tabs.
  3. Apr 8, 2018 at 4:12 PM
    Haikin
    Thank you. I will check them out, Firestone did mention during last alignment the tabs on the cam bolts might have been damaged. Not sure if they damaged them or not.
  4. Apr 12, 2018 at 3:32 PM
    Haikin
  5. Apr 12, 2018 at 3:38 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Could be lower control arm bushing
    Others have talked about this
    My05 did it until frame replacement, lCA and bushings were replaced in the deal
  6. Apr 12, 2018 at 3:57 PM
    Haikin
    That what it seems like the bulk of my searches have pointed towards. Should I go back to Firestone and give them hell for not torquing the LCA bolts properly
  7. Apr 12, 2018 at 4:15 PM
    tacofish
    N NJ
    14 ext cab 4x4
    wouldnt give them hell, tell them about prob and ask them to check
    Not sure why it would start after alignment
    There is a thread some where on here about it
    if its the bushings seems to be a prob with some tacos
  8. Apr 12, 2018 at 4:16 PM
    Haikin
    You're definitely right, just a knee jerk reaction to blame the last person who touched the vehicle. I will search around for it. If you find the link please share
  9. Apr 12, 2018 at 4:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Out of warranty?
    Modifications in the area?
  10. Apr 12, 2018 at 5:55 PM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    It’s the steering stops.
    On the front and rear of the spindle, down low by the ball joint bracket is a V-shaped stop that catches a nub on the LCA. The pop you’re hearing is those two making contact while the suspension is moving.
    It’s wayyyyyy louder on my BDS lift spindles.
  11. Apr 12, 2018 at 6:21 PM
    Haikin
    Still under warranty. I have a fox setup but I hope the dealer won't even mind that and just diagnose it
  12. Apr 12, 2018 at 6:25 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    I had that issue on my old t-100 and I put some grease on them and the pop disappeared immediately
  13. Apr 12, 2018 at 6:35 PM
    MCDavis
    RIC, VA
    Yeah I’m going to do this on the next rotation. It only happens to me once a week or so. I haven’t wanted to crawl back under the truck in the past few weeks after the coilover install.
    May even polish the stops a bit.
  14. Apr 12, 2018 at 6:48 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Axle grease is quite effective. My 93 was terrible. The plastic caps for the steering stops would wear out so quickly that I even kept new caps in the glove box as spares.
    kgilly[QUOTED] likes this.
  15. Apr 13, 2018 at 3:41 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Same with mine...
  16. Apr 28, 2020 at 10:10 AM
    Tacoooma13
    Tacoooma13 Active Member
    Cole
    2016 Grey SR Tacoma
    3inch Rough Country N3 struts and N3 shocks. Freedom offroad UPCAs. Rough Country bull bar. 42inch curved light bar. roof rack. 20×10 -25 Arkon Lincoln. Achillies Desert Hawk x-mt. Afe drop in filter. LCE header and LCE 2.5" cat back.
    My 2016 pops in full lock either direction aswell. Although its probably my tie rods since I'm running 20×10s wrapped in some nice muddies. The original wheels were 16inch
