Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Feb 22, 2012 at 6:31 AM
    #201
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Gabe is right, your only concern would be whether the wheels clear the caliper. Some brands of 16's do not. so it would be best to test fit them first.
  2. Feb 27, 2012 at 1:34 PM
    #202
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    yes i read now just plain confused!
    18x9 wheels 5"bs
    what offset do i need? -12 12 0?
    6" lift here relentless bumper :D umm help?
  3. Feb 27, 2012 at 1:38 PM
    #203
    TexasTacoma37
    If the wheels have 18x9 with 5BS, they are zero offset. You can't choose offset and backspacing, only one or the other. They are two ways of saying the same thing.
  4. Feb 27, 2012 at 1:42 PM
    #204
    FamouzStarz
    21 TRD PRO
    and the clouds parted and all was clear! woot woot thanks!
  5. Feb 28, 2012 at 7:19 PM
    #205
    Dexter1028
    Dexter1028 Active Member
    Kirk
    Pennsylvania
    2011 DC/SB OFFROAD
    2.5" Leveling Kit
    New to customizing and think i have it figured out but thought it was better to ask from guys who know what they are talking about. I like the Hostel EMR 811 17X9 wheel. They come in 0, 12, 24 offset. So I would want the 0 offset or would I want the 12 offset. I am planning on getting 265/70/17 tires. I thought I could get BFG but the specs say thy are only good for up to a 8.5 wheel so I am going with the General AT2. I have a 2011 TRD Offroad with a 2.5 leveling kit. Would this tire and wheel package work without any trimming or anything? Thanks in advance to anyone who can answer this question.
  6. Feb 29, 2012 at 5:40 AM
    #206
    TexasTacoma37
    If you only want 265's, you could go with either the zero or the +12.
  7. Feb 29, 2012 at 9:29 AM
    #207
    Dexter1028
    Kirk
    Pennsylvania
    2011 DC/SB OFFROAD
    2.5" Leveling Kit
    Thanks for getting back to me KPT. I appreciate it. I thought about going to a 275/70/17 but didn't think a. They would fit or b. can't find any that will work with a 9" wheel. Do you have any suggestions?
  8. Feb 29, 2012 at 10:52 AM
    #208
    TexasTacoma37
    Those would fit. People fit 285/70/17's with trimming.
    you would need the 0 offset to do it though.
  9. Feb 29, 2012 at 12:17 PM
    #209
    Dexter1028
    Kirk
    Pennsylvania
    2011 DC/SB OFFROAD
    2.5" Leveling Kit
    I only have 2100 miles on my truck so I can't bring myself to start trimming things. I'll go with the 0 offset though so in the future I can still use the wheels if I go larger on the tires. Thanks again I appreciate the help.
  10. Mar 8, 2012 at 12:04 PM
    #210
    Pigpen
    Dan
    Northwest Montana
    Just got my 2012 Taco (first Yota) and need to be able to run front chains. Yes need. This thread seemed to have the best solution. Anyone know what backspacing I need for a 16" wheel running stock size tires? Running real offroad v-bar chains to get into and out of elk camp.
    Thanks!
  11. Mar 8, 2012 at 10:22 PM
    #211
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Great info here!!! One of the main causes of vibrations is using wheels that are not hub-centric. Sometimes rings are provided and sometimes they are not, but the average guy might not know any better and they end up with headache.
  12. Mar 10, 2012 at 7:31 PM
    #212
    whitetacoma1
    whitetacoma1 White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
    very nice write up!
  13. Mar 10, 2012 at 9:58 PM
    #213
    haynstyle808
    haynstyle808 Active Member
    sorry guys little confused here, if someone could help answer my question. I was wondering how its possible to have a 9" wide rim with 5" backspacing and 0 offset. Wouldn't 4.5" of backspacing be a 0 offset since 4.5" is half of 9"??? I also see 9" wide rims with 4.5" backspacing and -12 offset. Not sure if i am looking at the picture right but could someone explaing? Mahalo!
  14. Mar 11, 2012 at 8:33 AM
    #214
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    www.rsracing.com/tech-wheel.html go to this link if u have not already...in the end what are u looking to accomplish? What wheels are u wanting or have a ? about?
    a 9" wide wheel with -12 offset will bolt up at 4.5" into wheel
    a 9" wide wheel with 0 offset will bolt up at 5" into wheel
    make sure you are not looking at two wheel widths ex: 17x9 & 17x8
  15. Mar 11, 2012 at 3:04 PM
    #215
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    a simpler way to think about this is to add 1" to the advertised size. for example, a 17x9 wheel is actually 10" wide lip to lip. 0 offset would mean 5" BS.
  16. Mar 12, 2012 at 1:33 PM
    #216
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    The more I read and try to understand the more I think I confuse myself. Specifically with an 18x9 wheel, what is the difference in 0 offset or going with a -12 offset. What complications should I be expecting? Any recommended tire sizes as to have the least amount of trimming if any?
    Im asking because I want an 18" wheel but there just seems to be such a limited selection when looking for a -12. Tires as well. Thanks for anyones help.:facepalm:
  17. Mar 12, 2012 at 4:07 PM
    #217
    haynstyle808
    Thanks gabe and fcs. Good explaination and great link. Makes sense now since...width and centerline are measured from two different reference points (inside the lip compared to edge of rim)
  18. Mar 15, 2012 at 2:43 PM
    #218
    TexasTacoma37
    The -12 offset will stick out one inch more and sit 1" further from the uca, than the 0 offset wheel.
  19. Mar 27, 2012 at 1:20 AM
    #219
    trdizzle
    trdizzle Well-Known Member
    Mark
    Oahu
    08 prerunner
    Ome kit, 885 coils.
    Question. I have an OME 885 on my 08' DC, was looking at running konig countersteer type x with a b.s of 4.1 and an offset of -10, can somebody tell me if i need to do a cab mount chop? i have LR UCAs, and was gonna run them with 285's.
  20. Mar 27, 2012 at 1:43 AM
    #220
    pontastic1
    pontastic1 Well-Known Member
    Pon
    NorCal
    '11 MGM DCLB TRD Sport
    OME 885 + TSB/AAL, Light Racing UCA, Fold-A-Cover G4 tonneau, OEM bedmat, AMP Bed X-tender, Neoprene Seat Covers, Weather Tech floor liner, Pop-N-Lock, UltraGuage, more to come.....
