Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Feb 15, 2013 at 8:33 PM
    #421
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    KPT, I read all throughout here and wheel spec thread but I can't seem to understand much of it.. Here is what I want to get for my stock 13' tacoma prerunner 4x2: http://www.4wheelparts.com/Wheels/S...?t_c=11&t_s=210&t_pt=100073&t_pn=PXA8101-7983
    Those are 17x9 Backspace = 4.75in. Offset = -6.6mm
    Stock: 17x7.5 bs 4.5'' +30mm offset
    Will I have any issues with rubbing and them fitting on to my stock dunlops?
    Thanks
  2. Feb 15, 2013 at 8:51 PM
    #422
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Anyone?? Lol
  3. Feb 16, 2013 at 4:49 AM
    #423
    ScubaTacoma
    ScubaTacoma Member
    Juan
    San Juan, PR
    2012 Tacoma V6 4x4
    35% Tinted Glass in Front, 20% Rear windows. Factory Roof Rack, 17x9 -12mm Fuel Throttle Wheels with factory Dunlop 265/65-17 Tires.
    Fiveoh, you're correct. -12mm offset (4.5 bs on a 17x9 wheel) should be fine if you're looking for that stance. That's exactly what I have, and I like the look a lot. You will find 265-65-17 tires that fit 17x9 rims, like Falken, BFs, or Nittos. Good luck.
  4. Feb 16, 2013 at 6:37 AM
    #424
    KPT
    KPT sees what you did there.
    09 Prerunner
    If the stockers are approved for 9" wide wheels, you are good to go
    I believe the max tracks require a certain backspacing. There would be no way to make the wheels tuck in like stock.
  5. Feb 16, 2013 at 8:58 AM
    #425
    sfcadams
    Dan
    Elizabeth, Indiana
    I thought maybe you might have to run a certain offset or something...
  6. Feb 16, 2013 at 1:06 PM
    #426
    pugdaddy2576
    pugdaddy2576 Active Member
    Brad
    Central Ky
    02 Tacoma SR5 TRD
    Grey wire mode, deck plate mod, 3" lift
    Im sorry guys but after reading the threads im more confused now that i was when i started. Im looking to buy to some new rims with my tax refund. A few years ago i bought a set of rims off of a buddy that came off of a 92 tacoma. Unfortunately the backspacing was not what i need (front rims rubbed on the brake calipers). So i bought 1.25 spacers which i havent liked since i bought them. My taco is a 2002 and i just bought a set of 33x12.50x15 BF Goodrich all terrians. So I need a 15x10 rim but what offset/backspacing do i need? I like the stance my truck has with the spacers (wheels stick out about 2-3 inches) but just want to get rid of the spacers. Any help is appreciated.
  7. Feb 17, 2013 at 3:40 PM
    #427
    KPT
    09 Prerunner
    Look in the ~3.5" range
  8. Mar 2, 2013 at 10:11 PM
    #428
    Taco.Supreme
    Taco.Supreme Member
    Dale
    Kelowna, BC
    07 V6 DBL cab
    Hey guys,
    I've been creeping around this forum for a good while now and am in need of some help. After reading through this thread I'm still a little hazy about what will work on my truck. Summer is coming up and I'm getting new wheels and tires for my 07 TRD Sport. I'm looking at REV 805 Wheels (17x9, 11mm offset and 5.5"BS) or REV 990 wheels (17x9, 20mm offset and 5.8"BS). The tires I'm looking at are Toyo Open Country MT's (285/70/17). I have a standard 3" lift with airbags in the back. Being 33's will I encounter any problems other than minor trimming, etc?
    I'm so greatful that I stumbled upon this community. I've learnt so much and I'm having an amazing time making my truck mine. Thanks to everyone on here!
  9. Mar 2, 2013 at 11:19 PM
    #429
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    Hey KPT,
    Planning on purchasing this: http://www.4wheelparts.com/Wheels/S...?t_c=11&t_s=210&t_pt=100073&t_pn=PXA5001-7983
    It's the Pro Comp 5001 17x9 4.75 bs 6.6 offset will that be okay for a stock suspension?
    also, I am pretty sure it is going to fit my AT20 Grandtrek tires they are ranged for 7-9.5'' wide rims.
    Just want to make sure I wont be rubbing anything and that it will fit my tires Thanks for the help on this post, and my previous post.
  10. Mar 9, 2013 at 3:29 PM
    #430
    Kevenass
    Kevenass Member
    Lac St-Jean, Canada
    08 Tacoma TRD 4x4 Double CAB
    Hello i have 4 mickey thompson mtz 265-70-r17 tire And i want buy wheel and i would like to have a little offset but no rubbing. Which backspacing and which wheel wide and which offset do you propose to me?
    I have a 2008 tacoma trd double cab with no lift for the moment butnit will comming soon.
    Thanks
  11. Mar 9, 2013 at 3:43 PM
    #431
    KPT
    09 Prerunner
    neither of those will work for you. They have too much backspacing. You need 4.5" to clear the 285s from the uca.
    You should be good to go with that.
    8" wide wheel, 4.5" bs
  12. Mar 10, 2013 at 4:40 AM
    #432
    Taco.Supreme
    Taco.Supreme Member
    Dale
    Kelowna, BC
    07 V6 DBL cab
    "neither of those will work for you. They have too much backspacing. You need 4.5" to clear the 285s from the uca."
    Plan B - from what I've read, stock sport 17's with spidertrax 1.25" wheel spacer will work?
  13. Mar 10, 2013 at 2:47 PM
    #433
    KPT
    09 Prerunner
    Yes, they will clear the ucas. You'll still have to trim to fit the tires though
  14. Mar 14, 2013 at 9:01 AM
    #434
    JimTXTRD
    JimTXTRD Member
    Jim
    Florida
    11 TXTRD
    Pro Comp lift, K&N CAI, Eclipse In-Dash Nav/Audio-Video System, Smitty Bull Bar, Flow Master American Thunder Dual Exhaust
    Looking to put 275/75/16 Toyo's on my 2011 4x4. Have a 11/2" pro comp leveling kit on the front and the new four pack leafs on the rear. My question is with the stock TX rims will I need any back spacing to prevent UCA rub? Current tire size is 265/70/16 difference in the width is approximately 1/2 inch and 5 inch gain in circum.
  15. Mar 14, 2013 at 10:50 AM
    #435
    KPT
    09 Prerunner
    Who makes a 275/75/16?
    And how big is the leveling kit :confused:
  16. Mar 18, 2013 at 5:18 AM
    #436
    JimTXTRD
    JimTXTRD Member
    Jim
    Florida
    11 TXTRD
    Sorry about that, fat fingers. The tires are Toyo 285/75/16 32.8 height /11.3 width. Pro comp two inch leveling kit on the front. Worried about UCA clearance.
  17. Mar 18, 2013 at 7:59 AM
    #437
    KPT
    09 Prerunner
    You're going to have to trim a bunch of plastic and likely chop your cab mounts to get those to fit. They are going to rub substantially even without any suspension flex. I believe the TX wheels have 4.5" BS, so they wouldn't be an issue for UCA clearance.
  18. Mar 25, 2013 at 11:34 AM
    #438
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    I am buying new rims and tires and I think I understand but want to make sure. I have 285/75/16s on stock rims (TRD OR). 3 in lift w/ LR UCA and 1.25 wheel spacers. I like the stance so if I go to an 16X8 in rim and do away with the spacers would I go to an 4 inch BS and -12 offset or 4.25 BS and -6 offset?
    How about 16X9 in rims?
    I rub a little on the mud flaps but a tie wrap takes care of that. Could a 305/70/16 fit?
    I believe stock rims are 5.25 BS and +32 offset
    Thanks for your help
  19. Mar 25, 2013 at 12:07 PM
    #439
    KPT
    09 Prerunner
    16x8 with 4.5" bs would give you the least rubbing. The 4.25" and 4" bs will mean you'll have to cut more than with the 4.5".
    305s will fit too if you are willing to cut and trim even further.
  20. Mar 25, 2013 at 9:51 PM
    #440
    DBroman3
    DBroman3 Member
    Don
    Irvine, CA
    2013 PreRunner SR5 2.7 4x2
    Working On it
    With this wheel, running 285/70/17 @2.5 lift. Am I more likely to rub cab mount with these wheel specs vs. another option?
