Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Mar 26, 2013 at 5:34 AM
    #441
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    So the calcuations are the 5.25 BS minus the 1.25 spacers plus .5 inches for the larger rim is the 4.5 " BS. is this correct thinking?
    Thanks again for your help
  2. Mar 26, 2013 at 5:46 PM
    #442
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Additional width has no affect on backspacing. It's an independent measurement. Sonifnyounhave a 7" wide wheel with 4.5" bs, and an 8" wheel with 4.5" bs, all of the additional inch will be on the outside edge of the wheel.
  3. Mar 27, 2013 at 11:37 AM
    #443
    CATwrencher
    CATwrencher Member
    James
    Louisiana
    2002 TRD Tacoma
    Well finally my first post. I have a 2011 taco dcswb TRD off road. Looking at picking up some rims and wanted your expertise KPT. I have scanned through the posts and have not seen this size mentioned nor have I seen you stumped yet so here goes. I have the tsb springs and billies set a 1.75. Will these rims fit and what biggest tire you think it can handle with minimal or no trimming. The wheel specs are;
    Bore-106.2mm
    Offset-+0mm
    Bolt pattern-6x139.7
    Size-16x8.5
    Your expertise is greatly appreciated!
  4. Mar 27, 2013 at 7:11 PM
    #444
    CATwrencher
    CATwrencher Member
    James
    Louisiana
    2002 TRD Tacoma
    Bump. I'm new to this.
  5. Mar 28, 2013 at 9:45 PM
    #445
    jmirage04
    jmirage04 New Member
    Miami Fl
    Stock 2013 trd sport
    Which wheel would fit better on a 2013 trd sport dblcab???? (Fuel Trophy 551) 17x8.5 -6 offset 4.5 backspacing or ( Method) 17x8.5 0 offset 4.75 backspacing. Toyo A/T II Open Country 265/70/17. I have stock height suspension. Thanks in advance
  6. Mar 29, 2013 at 9:24 AM
    #446
    TexasTacoma37
    Ether one is fine
  7. Apr 5, 2013 at 1:30 AM
    #447
    boto
    boto Active Member
    Philip
    Quebec/Canada
    07 taco dbl.cab.long bed TRD
    fog anytime bhlm royal purple oil kn&n oil/air filter secondary filter removed ultimate lift kit toytech 3 inch coilovers ans add a leaf relentless fab diy bumper
    does the 17x9 , 4.5bs ,-12 ofset stick out of the truck with 265/70/17 and with the 285/70/17 thank alots
  8. Apr 6, 2013 at 2:16 PM
    #448
    TexasTacoma37
    The wheels themselves will stick out 2.5" more than stock
  9. Apr 6, 2013 at 5:41 PM
    #449
    Jdd1091
    Jdd1091 Active Member
    I put 18x9s - 0 offset with 275/65/18s on a 2011 Tacoma DC Prerunner with a 2 1/2" lift.
    No rubbing and kept the mudflaps
  10. Apr 6, 2013 at 9:51 PM
    #450
    dcreech
    dcreech Active Member
    Dylan
    Columbia, SC
    02 prerunner v6
    2 inch toytec front leveling kit, 32 in discovery AT3's
    I'm sure this kind of question has been asked plenty of times on this thread, but I'm looking for decent, black, steel or aluminum wheels that give the right amount of offset/backspacing to make my 275/65/16's stick out about two or three inches from the fenders of my truck (if that's even possible). Any amount of help on this would be awesome! Thanks!
  11. Apr 11, 2013 at 6:22 AM
    #451
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So I though offset and backspacing were the same? Expect offset was the metric measurement and backspacing was an imperial measurement.
    For instance, my rims are 9" wide with a 0mm offset, so the backspacing should be 4.5" right?
  12. Apr 12, 2013 at 5:35 AM
    #452
    Jdd1091
    No.
    BACKSPACE measurement NEVER changes regardless of wheel width.
    OFFSET measurement is relative to wheel width.
  13. Apr 12, 2013 at 11:50 AM
    #453
    Alby9999
    Alby
    NNJ
    Sorry to bother everyone but I need to understand this.
    I am trying to find out how much a wheel will stick out in comparison to stock. I know I should go with 4.5 inch backspacing.
    First off, stock TRD OR alloy 16" wheels are 7 inch +32mm offset????
    Mathematically, which I probably have wrong.
    (1/2 rim width)-(offset)= distance from mounting surface to outside rim??
    stock would be:
    3.5-32mm(1.25 inches)= 2.25 inches
    Going with 285/75/16 on 16X8 or 16X9 rims 4.5 Back spacing offset unknown
    I also have a 1.25 in spacers so I would add to the figure above and get 3.5 inches
    When I measure I am incorrect. I would like a rim that would stick out about 1 to 2 inches more than what I have and eliminate the spacers.
    Help???? I am just not getting it.
    going with 285/75/16 on 16X8 or 16X9 back spacing 4.5 offset unknown
  14. Apr 12, 2013 at 7:01 PM
    #454
    Jdd1091
    16x8 with 4.5" backspace = 0 offset
    16x9 with 4.5" backspace = -12 offset
    It is pretty confusing.
  15. Apr 13, 2013 at 8:06 AM
    #455
    replica9000
    2019 T4R ORP
    So if my rim is 9" wide, and 0mm offset, that means the mounting surface is dead center of rim, why is backspacing not exactly 4.5"?
  16. Apr 14, 2013 at 8:22 PM
    #456
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    9" width wheel is measured inside rim to rim. Add 1/2" x 2 for the two rims.
    If you lay a 9" wheel, flat on it's back and measure from the floor, up to the front, it's 10"
    Backspace is measured from mounting surface to outside of rim
    See picture in 1st post, this thread.
    I made some simple drawings, here, to understand it myself
    Should clear it up for ya.
    picture's worth a thousand words, etc.
    BTW, the term "rim" refers to the metal portion of the wheel, that the tire bead makes contact with.
    CC
  17. Apr 14, 2013 at 10:40 PM
    #457
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    will I run into rubbing issues on the uca with 17x9 and 0 offset wheels on 285/70/17?
  18. Apr 16, 2013 at 6:05 AM
    #458
    replica9000
    2019 T4R ORP
    This is the part I didn't realize. Thank you.
  19. Apr 17, 2013 at 7:48 AM
    #459
    TRDPhreak
    TRDPhreak Like a boss
    Massachusetts
    2013 TRD Sport
    2.5" Leveling Kit - TUFF 17x8 AT T01 Wheels - Kumho KL71 265/70/17 MT
    I think I'm doing this correctly (probably not though). I have stock 17" TRD sport wheels on now. I am getting a set of 17x8 with 4"BS and -13mm offset. Does that mean the new setup will stick out 2.01" more than stock? I'm taking the 1.5" difference in BS and adding the -13 offset (.51") together.
    How'd I do?
  20. Apr 17, 2013 at 2:47 PM
    #460
    TexasTacoma37
    That's not actually the right way to do it, but you came out with the right answer.
    the 1.5" less backspacing should be added to the 0.5" additional width to make 2.0".
