Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Apr 17, 2013 at 2:55 PM
    #461
    TRDPhreak
    TRDPhreak Like a boss
    Massachusetts
    2013 TRD Sport
    2.5" Leveling Kit - TUFF 17x8 AT T01 Wheels - Kumho KL71 265/70/17 MT
    Is that because the stock wheel is 7.5 and not 8?
    If that's the case, what about the -13 offset? At that point wouldn't it end up being 2.51"?
  2. Apr 17, 2013 at 3:57 PM
    #462
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes on the width. And the offset is just a different way of describing backspacing, and visa versa. So you are double counting if you use both in a calculation.
  3. Apr 17, 2013 at 4:01 PM
    #463
    TRDPhreak
    Massachusetts
    2013 TRD Sport
    Ahh, gotcha. Thanks for the help. :cheers:
  4. Apr 27, 2013 at 1:19 PM
    #464
    hockeyplayer47
    hockeyplayer47 Member
    David
    North Carolina
    06 Tacoma V6 SR5 4.0L 4x4
    2.5" Front Lift 1" Rear Block Chrome Exhaust Tip Cherry Bomb Glass Pack Westin Bull Bar Black UWS Tool Box 5% Tint Aftermarket Radio Fog Light Anytime Mod Black Billet Grill Black Headlight Housing 6000k HID Smoked Taillights
    I have a 2006 tacoma with no lift. I want to put 17x9 rims on it with 4.5" of back spacing and -12 offset. would that work?
  5. Apr 29, 2013 at 5:56 PM
    #465
    acro
    acro Member
    Curtis
    Arizona
    2.7 Tacoma
    Metallic dark grey,debadged, nearly dechromed,
    This all might be a bit more helpful if everyone knew what the specs/measurements of their stock rims are. I would like to know what mine are as an impromptu jumping off point. We all should know the rim size. Doh! It's on your tire. The other dimensions/measurements do become confusing. My stock steel 15s appear to have very little offset, (nearly a flat face) but I don't actually know what the offset really is. Of course, not much of this matters if you are going to lift. Thanks for reading. I'll watch for comments. This is my first post and I am shopping for wheels. My last Tacoma was a '96 with 14s and wheel covers. It played cassettes but there was never a drip or drop of anything in the driveway.
  6. May 3, 2013 at 6:40 AM
    #466
    Saren
    Saren Member
    Sara
    Idaho
    2010 Super White TRD Off-Road
    MagnaFlow off-road exhaust, OME 885 lift w/ rear full Dakar leaf pack, anytime foglight mod and Contura V switch, aFe Pro-Dry S filter, color-matched grill, Yakima rack, ARE Z-Series shell, and probably more. Also have a 1996 regular cab SX Tacoma, a 2001 extended cab SR5 Tacoma, and a 2014 DCLB Tacoma.
    Alright, I have to say that I didn't make it through all of the posts (tried, but failed) and at some points it made sense and then I would get all confused again. Anyway, though I am a member of the female gender, much like some dude in some thread (this one?) said, a diagram works to explain things in the best way.
    Just saying. Ahem.
    So- I went to one of the sites *first* posted which helped to compare tire/rim sizes and convert metric to US standard; then I went to one posted soon after--and let me tell you, ALL the info anyone needs is between these two sites. :eek: And the second one has pretty little diagrams that adjust according to your inputs! :cool: So cool.
    The only thing we need now is a calculator that takes into account if you are adding a lift kit--though, it doesn't take much thinking to figure that out, methinks. For instance, in my calculations, my new rims with the stock tires will move the wheels out 0.7" (not a problem, I measured). If I got new tires before getting a lift, I would fill out 13mm more of wheel well (according to rimsntires). Not a problem for my truck, again. Ta-da!
    P.S.
    Don't be silly. You're not confused because you're a girl... :facepalm:
  7. May 14, 2013 at 8:58 AM
    #467
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Just need a ok here.
    I have a 2007 taco trd sport. Have stock wheels, 17x 7.5",with 5.5" backspacing.
    Will be adding tsb and add a leaf in back, still undecided in front, probably spacer but if not spacer, A lift that will not be more than 3".
    Considering 4 runner te wheels, 17x 7.5", with 4.5" backspacing.
    Will be sticking with 265/65/17 tires, and at most 265/70/17.
    My question is, are the 4 runner wheels ok to fit.
    Thx for the help.
  8. May 16, 2013 at 8:45 PM
    #468
    DSully72
    DSully72 Well-Known Member
    Daniel
    Newport News, VA
    04 PreRunner TRD Off Road
    so I have a question about the whole backspacing vs. offset thing. I'll use the Mickey Thompson Classics as an example. How is it mathematically possible for a 16x8" rim to have a backspacing of 4" but an offset of -12mm? if the backspacing (the back of the wheel to the mounting surface) is 4", that would put the mounting surface smack dab in the center (because 4 is one half of 8), so it would make sense to me that the offset would be 0mm? Can someone help me understand how this is possible?
  9. May 18, 2013 at 7:07 PM
    #469
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I answered a similar question for a 9" Wheel on the previous page, here
    Should clear it up for ya
    CC
  10. May 23, 2013 at 4:46 AM
    #470
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
  11. May 23, 2013 at 2:45 PM
    #471
    DSully72
    Daniel
    Newport News, VA
    lol yeah I got it all figured out, apparently you have to add 1" to the width of the wheel... who knew? :notsure:
  12. Jun 6, 2013 at 11:01 AM
    #472
    BLiX
    BLiX New Member
    Alabama
    2013 PreRunner SR5
    I am new to trucks and I'm needing to know if a 16x8 rim with +10 offset fit a 2013 prerunner with factory suspension and tires?
  13. Jun 7, 2013 at 10:25 AM
    #473
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    Hi guys, I am another noob that needs help piecing this together for the first time. Looking at some Nitto Trail Grappler 280/70/r16s. I have a 3" Toytec ultimate lift. What do I need to be looking at for backspace and offset for an optimal fit? I know I have seen similar setups on here. I think it was no greater than a 4.5" backspace and not sure of offset? Any help is appreciated. Thanks folks.
  14. Jun 7, 2013 at 1:50 PM
    #474
    DSully72
    Daniel
    Newport News, VA
    id go with a 4" backspace if possible. not sure which rims you are looking at but if you are looking onto steelies, summit racing sells 16x8 with a 4" bs for $55 a piece. they have both the cirlce hole design and the D shpaed hole design. other rims you just have to take a look at the specs.
  15. Jun 19, 2013 at 12:54 PM
    #475
    Costa09
    Costa09 Well-Known Member
    GA
    08 PreRunner
    Okay I admitt I didn't make though all the posts. I made it half way and still need some clearing up on my new setup. I already made a thread before I found this one. No sold answers that make me feel confident to pull the trigger on 1500 dollars of new rims and tires. I have searched and searched and I find some that say yes it will work and others no. Here is my question, I have a 3" OME lift and light racing UCAs I am currently running 285/70/17 with 17x9 XD Addicts with 4.5 BS and -12 OF. Have done trimming to plastic for these. I want XD Cranks 18x9 5 BS and 0 OF with 285/65/18 nitto Tera grapplers. Will it work or will 275/70/18 be better and keep me from chopping my cab mount.
  16. Jun 20, 2013 at 11:36 AM
    #476
    Costa09
    GA
    08 PreRunner
    Anybody help me out on the post approve? I also concerned I will scrub my UCA. Is 275/70/18 better option or can I run 285/65/18? Thanks again this is just bugging me. I really want these rims.
  17. Jul 15, 2013 at 4:00 PM
    #477
    JMooney9
    JMooney9 Member
    hey guys i got a 2011 doublecab tacoma with a 3" suspension lift, and i was looking into getting new rims and tires, looking to extend the tires out past the fender flares 1 - 1.5 inches on each side, i was thinking on running an 18" rim instead of a 17, any suggestions on what size tires to get and how much backspacing/offset for the rims? would 285's fit?
  18. Jul 15, 2013 at 8:27 PM
    #478
    Costa09
    GA
    08 PreRunner
    After market UCA's? I ran 285/70/17s. BFGs and XD Addicts. -12 offset and 4.5 back spacing. With minor trimming of the plastic inner fender well. Most will tell you to stick with 4.5 BS or less which is a good way to know that you will clear everything but all the guys that run rockstars have a 5 BS and it works with 275 tires, have heard of some 285 fitting also. When I was looking into new wheels I was told not to run 285 or larger with a 5 BS because of UCA clearance. But with my new 20s I just got I have a 5 BS and have the room for 285s I think. I got 275/60 to be safe ended up with a lot of room. Every truck is different though. I hope this helps some!
  19. Jul 17, 2013 at 1:46 PM
    #479
    JMooney9
    JMooney9 Member
    stock uca's. i may just go with 275/70/17's just to be safe, along with the XD addicts with 4.5" backspacing
  20. Jul 17, 2013 at 2:36 PM
    #480
    Costa09
    GA
    08 PreRunner
    I ran 285/70/17 with addicts for 2 years. The fake bolts will fade on you over time also.
